- Jun 16, 2003
So which makers use 80CrV2?
ED:
Rick Marchand
J.W. Bensinger
Daniel Winkler
ED:
Rick Marchand
J.W. Bensinger
Daniel Winkler
Alright, so you have great edge holding and when differentially HT'd is as tough as any steel needs to be, what more can you ask for. I know that today we like super steels(my term) like 3V, INFI and some others, but well done 52100 can do it all and is one of the preferred custom steels.
Amen to that! Though I think one of the problems with 52100 is that it can be especially difficult to heat treat correctly. Bluntcut, Ed Fowler, and others are able to squeeze the most out of this steel with their intricate heat treatments, however, I've read that it has to be done exactly correct or you loose a lot of the steel's performance.
On the other hand, 80crv2 is a steel that matches up very well with even the best heat treated 52100. However, it is much easier to heat treat and more forgiving of mistakes where as 52100's optimum performance is the result of a meticulous and careful heat treatment that must be pulled off perfectly.
All squares are rectangles, but not all rectangles are squares.![]()
Rectangle: A 4-sided flat shape with straight sides where all interior angles are right angles (90°).
Also opposite sides are parallel and of equal length.
Example: A square is a special type of rectangle.
I wasn't saying that more carbon makes 1095CV better I just don't see anything about 80CrV2 that would lead me to believe that is at all comparable to 3V?
The toughness is similar (very high), due to similar structure (which is due to the same basic chemistry). 3V will have significantly better wear-resistance and corrosion-resistance, from much higher amounts of chrome, vanadium and moly. For people that don't mind sharpening a little more often, and don't care much about a little staining, 80CRV2 is absolutely comparable to 3V... the upshot is they can both make very tough knives that perform very well.![]()
It's reasonable to describe it as 1080 < 1084 < 80CRV2 < CPM-3V in all pertinent areas. Again, the only real difference is increasing amounts of alloying elements.
This is a waki made of 52100 with 6 step normalizing in precise digital control gas oven, double quench at 1500F in canola oil and triple temper at 400F. Gas torched to draw back the spine 2 time.
0.014" thick behind the edge. Can easily chopped through any 2x4 with zero damage.
We have done numerous test with 52100 to find the most suitable heat treat protocol to each of blade application in our use.
Simple to low-alloy carbon steel like 52100, O1, W2, 5160, L6 etc. with no selective hardening would have much higher risk to fail when it come to high impact application like wood wakizashi or very large camp, Those selective hardening/tempering also vastly improve shock absorption.
The reason for all of this are pretty simple metallurgy... 950F tempered martensite of these steel are much tougher, resilient and softer than 400F tempered martensite.
Pearlite structure also the same story but not as strong as spring tempered martensite.
[/URL][/IMG]![]()
https://www.youtube.com/watch?v=El-CWPcjIJs
I might have to disagree with you re W2 because in blades the size/thickness that you are talking about, it tends to "selectively harden" on it own. maybe 5 or 6 years ago, an member of BFC had MS Bailey Bradshaw make him a thorough hardened katana for competition cutting. the reason was that he wanted a tough sword that would not break in he case of a mishit, but one that would also not bend and take a set like ones selectively hardened or like traditional nihonto for that matter.
Edit. After reading again, you are not selectively hardening, but selectively TEMPERING, right? The old "blue back" trick. Also, if yo are looking for toughness, you might want play around with 52100 at 1475F.
A fine illustration of a common problem in communication: assuming that a single language is involved.
Churchill said the UK and US were "two great peoples divided by a common language." The same is apparently the case as between the language of mathematics and plain English.
In mathematics:
You are undoubtedly correct about the common understanding of "rectangle" and "square."
You are right, shallow hardening steel like W2 or 1095 when given thick enough section it may have selective hardening on it own.
In my country, it is very common among knivemakers to draw back the spine even it medium size blade... unless they to the clay hardening thought.
@Blain
Selective hardening is to harden the certain part of the blade around the cutting edge. Mostly used on low alloy carbon steel.
There are certain ways to do it such as ;
-Clay hardening, by using heat resistance clay to coat the spine of the blade or any area that want to be softer/tougher.. When austenitizing (use high heat in order to harden) and quench, the area under the clay won't cooling fast enough to pass the pearlite nose and majority of the structure would go back to pearlite while you have martensite cutting edge.
-Edge quenching, by austenitizing the whole blade but quench only the edge, quite similar structure as above
-Edge acetylene torching, by austenitizing only the edge very fast before the spine get hot enough... kind of similar structure as above.
Selective tempering is to harden to whole blade and after you do the regular tempering, you temper the spine of the blade again to the higher degree while soaking the cutting edge in the water to encumber the heat. Then you have cutting edge which are tempered martensite and spine of the blade that are even more tempered martensite.
Which one is better? tempered martensite are stronger, springier and tougher than pearlite... But won't get the nice harden line with this method thought.
It all depends on how it's done and the steels involved.
