Dadburn it! I was trying NOT to make it confusing.Karda your labeling is confusing. I like the second from the top.
Yeah the 1 inch hole is fine for me too. but i wanted to go about 1 1/4 inche approx. to accomodate larger fingers.I've found, after buying a few karambits myself, the 1" hole seems to be just about perfect for me. In post #20 (redesign "E"), you might want to make the angle from the outside diameter of the hole and the inner curve of the handle less severe. It appears to be less than 90 degrees right now. This angle was acceptable in your first illustration (redesign "A").
I'm Voting for Redesign F
Me too! Very nice work and a really great improvement Karda!!!!:thumbup:![]()
It really doesnt effect the grip at all if its larger. It makes it easier to put your finger thru, and theres less chance of breaking your finger should the K'bit get twisted outta your hand somehow.
... But, you might need to do some tests with gloves or larger fingers just to find what you like with this particular design.
KaliGman, I trust your judgement here. I'm sure you have much more karambit experience than I do. I also wear thin gloves, even in the winter. I'm usually using my finger for all kinds of things that require dexterity, so thick gloves are usually out.
I really need to make it over to your neck of the woods for some karambit training sometime in the near future.
Dan said:1 - the ring should be more "inline" with the fingers and 1"-1.25" in diameter
2 - the ring should allow "thumb room" on the backside
3 - the blade should be oriented more-or-less 90 degrees from the hand. The reason for this is to be able to allow a closed-fist hold where you can punch the blade forward and have it go straight in. A lot of kerambit-makers skip this aspect in favor of looks/etc.
4 - blade should be able to slice and slash (most designers get this one right)
