- Jan 18, 2015
I like how Nick wheeler goes so far as to file the tang to put keyways for the epoxy to lock onto.
I think he even files on his pins
On the epoxy packages don't they tell you about shrinkage?
I know while thumbing through my Brownell catalog they have tons of epoxy like acraglass and I believe they list the shrinkage factor not sure on this though .
I did clean everything well with acetone. I aplie quite a bit of acetone, then whipe it off with clean textile (cotton) to remove the solved grease, fat and dirt.
ACETONE is not what you want to use. It leaves an oily residue. Use denatured alcohol to clean with. If you do not have that then use dawn and hot water and wash until it is spotless.
West Systems actually recommends using acetone (or alcohol) to prep before bonding.
West Systems is WRONG. There is to much unpure acetone out there to be trusted. It is easy to see the residue it leaves, for that reasons those who know do not recommend acetone
Dishwashing liquid will clean a blade well for epoxy but I am always in the shop when I am ready to epoxy so I have been holding my breath and squirting a little carb cleaner on a cloth and wiping the blade before glue-up. It evaporates so quickly and completely degreases the blade and so it works well but you have to wear nitrile gloves to protect your skin. I clean the blade with acetone first but there is always a little residue. I use G-flex and glue on scales by putting a little weight on the scale and letting gravity hold the tang to the scale instead on using clamps which sometimes squeeze out too much epoxy. My method is slow because I only epoxy one scale at a time but I stress less about getting a tight fit against the guard or bolster. I am not saying that this is the best way to do it but rather just the way I do it. Larry
I'll touch on the obvious stuff:
Did you clean both surfaces well with solvents first?
Are you using a good quality epoxy such as Acraglas?
Is your epoxy fresh, was it measured out and mixed very thoroughly?
Did you over clamp it and squeeze the epoxy to thin?
Thnx for the input.
Here is a pic of the tang before glue up.
I used four hidden pinns (in the middle row of holes), two massive pins and tho with thread to give the epoxy more to hold on to.
What do you think of my idea of "hardening skinn" in the deeper parts of the roling skinn being a barrier between the epoxy and steel?
Should I have had holes closer to the end of the scales as well?
Also be careful when removing the glue residues from the front... useing too much solvent there could weaken the glue as far as it wicks, swollen the wood, and then the wood will shrink away from the tang
