A good backpack (where?)
I am looking for a good backpack for someone who enjoys walking out into the mountains of idaho and hanging out there for a couple days. Obviously it would need to be sturdy, waterproof, and have the ability to hold a couple things :D.
Thank you to all who give reccomendations.
~Jeremy
Walk into REI and get custom fitted for a 60 Liter internal frame pack. Expect to spend around $200 Money well spent.
The wife got me a Kelty Moraine 3600ci pack for Christmas. It's been discontinued by kelty, so good prices can be had on the pack (the wife paid $70.00). Not as adjustable as the higher priced packs, but still accepts a fairly wide range of torso lengths and is built rugged. The pack is water resistent, but I picked up a pack cover for it to help make it waterproof and loaded it with everything I'd need to spend 4 days in the backcountry. Yesterday I took it for a long hike and with the 26# load, it carried very well. It is same in material and durability to the Kelty Redwing pack, except that it is a top load instead of a panel load like the Redwing, so it has the additional storage in the hood, as well as more height for more carry capacity. I even had enough room left for another couple days worth of food if I wanted to extend my time afield.
Whatever you get, realize there is no such animal as "waterproof". Get some dry sacks or a good pack liner.
I recommend the opsrey atmos 35. I have one and absolutely love it. It has a whole lot of unique features. For example, it has a net that sits on your back instead of solid material to keep you cool. It will run you about $160. Sizes run from 1800 cc to 2300 cc or so.
Is this a gift for someone? If so, don't pick it for them. REI in Boise is a good place to shop. Kelty makes a lot of interesting things but there's a lot of competition in the pack market.
If the funds are there, and you want the very best, check out www.kifaru.net ... There may be something better out there, but I haven't found it yet (custom made for your body size and type). As for the more mainstream packs, I really like the Kelty Redwing for short jaunts through the woods.
Another vote for Kifaru and REI. The REI Traverse is a good pack for an extended day hiker.
Check out the Kelty MAP 3500.
It is tough, has a great suspension for long walks, holds alot of gear without being a HUGE pack, it is around 1950 c.u it, also has an orginizer pocket and comes in many cool colors. Also, it is affordable...$99.00-$130.00 depending on your color choice. This is really a great pack!:D
http://www.amronintl.com/tactical/products.cfm?id=631
Gregory has been in the business for at least 25 years, a good indication of value in a trustworthy product. A pack cover or poncho is best to keep stuff from getting soaked. In any type or brand, consider one a little larger than needed to carry your anticipated gear. That way stuff can go inside rather than strapped outside, something that bugs me when bushwhacking. :)Regards, ss.
I have heard great things about Kifaru.
I have a Camelback BFM. It is made from 1000d Condura so it is tough.
Its comfortable to the point that you will forget it is there, even when fully loaded. Comes with a 3 liter bladder and a drinking tube.
Kifaru is expensive, but it's the best pack I've ever had. (I have an Express with an E&E.)
Ditto on the waterproof -- the lack of it. Unless you are hauling a bag made for runnign whitewater, they will leak. You can use garbage bags for a pack liner or better yet trash compactor bags. Sea to Summit makes some silnylon pack liners. I use one silnylon bag for keeping socks and base layers dry and another for my sleeping bag. A pack cover will help, but can't be counted on for complete waterproofing for critical gear. A poncho works well to keep you AND the pack dry and can be helped with a waist belt (read piece of line) for wind.
Things to consider when buying a pack:
Volume-- how much space do you need?
Weight-- how much suspension do you require for the load?
Fit-- buy sized packs that fit you properly.
I go ultralight, with my base load (less fuel, water, food) at under 12 pounds. My all-up weekend trip load is about 21 pounds. With that load, I use a GoLite Jam pack. If you are going to be hauling 40-50 pounds (and you're NUTS to do that), then you need a heavier pack with a decent frame and suspension. It's just like buying boots, so I recommend getting to a store that knows what they are doing and has test loads available and trying some on and walking around the store. Look for simpler, sleeker packs with a minimum of pockets, straps and gee-gaws that just add weight. If you do a lot of bushwhacking then durability is an issue and you want heavier material. On regular trails, lighter materials are just fine with reasonable care. Every ounce you save on the pack is less weight on your feet, or another ounce of food, fuel, water, or other gear essential to the trip and your safety and comfort.
Lowe makes great packs w/ little frills--they have been in the business a long time and there's a reason...
Pack weight is just as important as the weight of what you will be packing.
Some of the top line wiz bang packs weight 6-7+ pounds dry.
You could be carrying 32 pounds or 28-29 pounds just depending of the pack you choose.
IMO a good pack should not weight much over 4 pounds. Do you really need all those fancy colored straps and buckles, 100+ attachment points, zippers everywhere ( they break ) etc. ?
alright i think I'm gonna go with this one.
do you think a good bungee cord could strap some snowshoes to the back without snapping those loops?
