Hi,
Huh?
The quantification would be very qualitative for the most part
and it wouldn't take long,
its just like a regular sharpening except on a scale
and you get a number you can relate to with a scale of your own
a little is like a pinch of salt
stone surface looks basically unchanged
blade rubbing on stone feels slightly more scratchy
scratch pattern left on blade is very harsh and linear
touch/dab finger to stone and it picks up grains of sand
rub finger on glass to check that it scratch the glass
a lot is like a layer of mud/frosting
stone surface changes color, looks coated in mud,
blade rubbing on stone feels very smooth since its riding on mud/slurry
scratch pattern left on blade is very smooth and random /shot-peened,
touch/dab finger to stone and its mud sticky, you get mud on your finger
I've done done quite a bit of searching on "P grade bond hardness"
and couldn't find numbers I could relate to more than "its hard"
to really make sense of it i'd have to get a p-grade wheel
The manufacturer ought to have an idea of the pressures required to break the bond
if they used a grade-tester , which are supposedly used for quality control
... but they could be simply grading by volume of binder to abrasive ...
it would be interesting to know
Thanks
Grades are actually dictated by product density. That density is determined by a simple mass/volume calculation. Since the bonds used are proprietary to manufacturers, each manufacturer has a different scale used and the letter hardness associated with the grade is therefore not consistent between manufacturers. Typically, based upon an average within the industry, a product of the same structure, but one letter grade harder is about 6% denser. Of course, hardness in itself is relative. A product containing less bond but manufactured with increased pressure may be as hard as one that contains more bond and pressed at a normal pressure. They will grind very differently though since the bond to grain ratio will be different. I hope that helps.
42 is nicer than I would be, it is a 7$ stone, and those are a bunch of needless questions. Buy one and try it out, I would chip in a couple bucks just to shut you up.
Have a day, Russ
:thumbup:42 is nicer than I would be, it is a 7$ stone, and those are a bunch of needless questions. Buy one and try it out, I would chip in a couple bucks just to shut you up.
Have a day, Russ
