Some days...
Come on weekend.
The regular or small Svord?
I wish I was able to snag one of the old Promo 4's, but it wasn't in the cards right now. Oh well..... I like the Svord and I especially like it with the blue handles!Damn, you take better photos than I do. It's a regular-sized Peasant, it was a B-grade (the finish wasn't uniform enough for the guys at Baryonyx to sell as A-grade) blue-handled one. I think the wood handle looks way better, but $10 is hard to beat for a knife like this.
Peppers won't set when the temps fall too low (<50?).
'Over-wintering' peppers is done to keep the root ball alive so it comes back like gangbusters next spring. If you're wanting to harvest peppers you'll need a 'hot house'.
I'm trying over-wintering this winter with a couple of my best producing plants. About a month before 'average first-frost date', I'll cut in back to about 18" leaving only a few mature leaves. This should force out new buds. About 2 weeks after they sprout and have developed good leafage, I'll cut off all remaining mature leaves. Just before first-frost, I'll dig up the root ball, trim it up, transfer it to a large pot with potting mix, and move it indoors. I've got a 'grow box' setup for sprouting seeds in the spring and it should give the peppers plenty of light and enough moisture to make it through the winter.
I have a 50 ft long x 8 ft screened porch that I am adding Lexan windows to for over-wintering and pre-starting plants for the spring. I have the Lexan panels cut. I;m building the frames for them now so I can set them in and take them out as required for temperature control and air circulation.
Anything below 60F will result in reduced fruit setting and below 55F will result in deformed fruit that does set. Below 50F, setting is negligible and long term (several days) below 45F, plant damage can occur. At the other end of the scale, over 85F, setting of fruit is reduced and above 90F, almost neglible. Anything that does set will be small and deformed.
Optimal pepper setting/growing temps are 65F to 80F , During the spring, daytime temps of 60ish and night temps of 50ish for a week or so can result in significant flowering when it does warm up but the flowers will be infertile and just sit there doing nothing.
The same temps apply to tomatoes, as well. I have some tomato seeds from plants that have been kept going by the family since they were first purchased in the 1960s. They are an indeterminant variety - Porter tomatoes. Small, about golf ball size. For the last 10 years, I have been keeping watch and any fruit that sets while the temps are above 90F get marks and I save the seeds from those fruits separately. I.m hoping to eventually select for a variety that will set fruit reliably when the temps are above 90F. This could be a good thing as here in Texas the 90s get here in May and keep going all summer. Rather than just keeping my tomatoes alive over the summer in hopes of milking a fall crop out of them, I want to have some that make good fruit all summer - "Z's Summer Setting Tomatoes".
WW, for smooth cut with few or no saw marks get a hollow ground planer blade. Dewalt has a 10" for twenty bucks. They are not carbide tipped and will dull quicker, so I wouldn't use it for everything. Only stuff that you want satin smooth. :thumbup:
Different blades with higher tpi will yield different cut patterns and coarseness left behind. But the finer the tooth, the more heat build up and more likely to scorch a piece of wood.
Do some research and see what blade types and tpi are proposed for the wood type and dimensions you are cutting.
WW - better blades = better looking cuts.
if you're chopping up framing lumber and plywood, 24-40 teeth on a combo blade if fine.
If you want nice cuts, 40 -60 teeth and slow feed rates. (not glacial, but not as fast as you can force the wood through, either)
I am a fan of the freud diablo blades - they give a decent cut at a reasonable price. Oldham and Forrest also make good blades.
if you want to cut really thin stuff, make a sacrificial table surface: with the blade all the way down, set the fence where you want it, then tape a piece of smooth plastic or luan plywood (1/8-1/4" thick) to the table flush against the fence. turn on the saw and slowly raise the blade up -- now your thin cuts won't fall inside the saw and get chewed up.
I'm sorry to hear about your parrot, Dresnor
I wouldn't put 15-1-1 "lawn fertilizer" on my lawn, much less a houseplant.The avocado will go into a bigger container with an organic soil mix... I doubt it will need any nutes at all for some time, but I'll look into it more and keep an eye on it. At this point I'm far more interested in growing roots than leaves.
I've always wanted dwarf orange or lemon tree. As for the pepper, this late in the year I'd put it in a pot, up to 5-gallons. Don't over-water it! Pepper plants hate wet feet. Pinch off the top once it's about a foot tall, and pinch off the flowers as they come in. With a little care and decent light, by next spring it will have a good strong rootball and lots of sturdy branches and nodes, and it'll be ready to go bonkers when warm weather comes and you can harden it off and put it back outside.
In related news, I'm about ready to trim back a couple of my smaller pepper plants and try some indoor bonchi gardening this winter... should be interesting.
Also, stop buying PSA sanding disks... just get a can of 3M Feathering adhesive and use whatever sandpaper you want. It peels off/cleans up easier and you'll save a few bucks.
Hey, I recognize some of that wood!
Glad you're having fun. Truth be told, I'm a teensy bit jelly....I wish I had more time to play withmywood.....
And I know what species of wood those pieces are....not that I would tell you given the "prize"!
Today marks the end of one of our favorite pets life, our parrot Micky. He was a Mini Hahns Macaw full of piss and vinegar. Amanda has had him since she was in elementary school and when we started dating he was part of the deal. He grew into a true companion and at times he just couldn't be without me. His funny remarks when it wasn't appropriate and his constant need for attention will be missed.
Please take time in your day to send some love his way this evening.
Thanks,
Jeremy
If you can get a variety that sets and yields reliably through the summer, I will work to have you declared a Texas Hero - which likely won't be hard.
At the very least, I'll show up at your door, hat in hand and cash in wallet, to get some seeds.
A 3.5 to 4 foot gator took a stroll down my dirt road this morning.... About a mile from the closest small pond... Not sure where he was headed but it wasn't towards any close water... Just out for a stroll I guess lol
Haha - The gator might be thinking the same thing about the random dude he saw on his stroll.
LMAO... Maybe... But if he walks past my house again I'm calling himdinneran inlay
-no joke
