Spyderco reports 565 vs 750 for CATRA so 33 %. This according to descriptions is the number of cuts to reach a specific state of blunting so it would corrospond to the 57 (8)% obtained in the above. These can't be compared in a meaningful way as there is no quality determination on the CATRA results, meaning no way to bound the expected performance. This comes from duplication on different samples to see how much the edge retention changes from one piece of steel to the next as well as just variation in the actual cutting, media, and initial sharpening.
It is possibly, though unlikely for example that the Military I had represents the "average" Spyderco blade more so than the Para/Manix. Using this blade vs the ZDP-189 would give a number very close to the CATRA results. Note what would happen in the extremes of comparing the Rat Trap to Calpyso Jr. or the Military vs the Delica. This is one of the problems when working with small samples and why it gets much more informative when you have a larger sample size.
As noted though you would never expect the number to be exact as they would depend on the edge finish, angle and even media. This is why to be comprehensive you could test on say hemp, cardboard and carpet with multiple knives for each and then in the end present an average increase in slicing aggression overall that media. Similar would have to be done then for push cutting.
As always, the above isn't done to represent a "final word" on the subject but mainly to outline how such work can be done and offer essentially one data point. This has to then be integrated into all other unbiased/non-shill information to obtain essentially the population behavior. I will be repeating this on carpet shortly hopefully if I can obtain some as that is much easier to work with as it is insanely abrasive and thus the runs are almost immediate.
I should do the push cutting work as well, but that is very tedious to measure. I should just buy a force probe as that makes it trivial and extremely fast and precise.
-Cliff
