I think we've reached the end of this test since I decided to up the ante with two days of salt water. After two days of spraying the remaining plates with isotonic salt water twice/day, and then 36hrs of rain -- intermittent downpours and drizzle -- the lubricants met their match:
The photos have shown the
best side, assuming that it had the proper application of lubricant and the other side was not necessarily applied enough/properly. Assuming that I removed the scale from the metal properly on each one and applied an even amount of each lubricant, it's pretty apparent which one protects the best. The kicker is that Eezox is a lousy lubricant. One other thing that I find puzzling is that the back side of the Eezox plate looked exactly like the CLP and WeaponShield plate. Until the last saltwater applications, the WeaponShield was doing better than the FrogLube and even the CLP. It may be that it doesn't hold up as well to salt water as FrogLube does, but for everything else it does better than FrogLube and just as well as CLP. It also lubricates a ton better than Eezox or CLP. I haven't tested out FrogLube's lubrication properties yet as that will entail dismantling the knife to heat up the tang for proper Frog Lube application. Maybe when my Contego arrives I'll give it a shot, especially since that's an M4 blade.
I may have to try this again after I figure out a way to consistently remove the scale from the welding plate and a more consistent way to apply the lubricant evenly. Of course, if anyone wants to donate a 3/32" or 1/8" thick 2" wide by 4ft. long bar of 1095 for this test along with some reinforced cutting wheels for my Dremel...:jdwink2:
Any future test would be sure to involve FrogLube in the kitchen setting since they advertise it as being made from food safe materials. Tomatoes, oranges, onions, mustard, etc. I'm also considering mixing 5W Nano-Oil (the best lubricant I've come across ) with some of the others to see if it improves their lubrication properties and how it might affect their protective properties. Maybe I'd even be able to find some Ballistol and include it.
