I have a question for those who want the sheepsfoot to pivot at the same end as the clip blade—what is the advantage?
I can tell you from experience, that the way Buck does it without the liners makes it a lot easier to wash out the inside of the knife. However those Colonials have nice thin blades, that can get really sharp, which I like.You can see that is a different construction than on the Buck three spring design—those knives have separate spacers between the springs. Bucks three spring design does not have those. I'm not saying one is better than the other; it's just that they are different.
Bert
Good question.I have a question for those who want the sheepsfoot to pivot at the same end as the clip blade—what is the advantage?
If Buck are retooling I'd like to wish for: 301 / 303
- Springs with bit more oomph!, more Chuck Norris and less Barbie's Ken...
I agree ! I hate nail breaking think they’re open enough and then bite you on their return to the blade well kinda knives. I definitely prefer the smooth constant opening of a Buck 300 series and no half stops. I can’t stand half stops! Also I would rather have the hollow grind. My hollow grind 301 takes and holds a good edge longer than my flat grind knives. I like the Buck 300 series like they are allbeit I’d like some jigged bone in the mix. And I’ll keep the spey blade thank you! And a low set sheep’s foot is my preference. If it’s to high I file the kick to lower it. The fact is everything on that list goes against what I like in a Buck 300 series and that’s why I prefer Buck!I'm not criticising you or your list alt all, but I very much hope that Buck doesn't make their springs stiffer. The high points of the 300 series knives include their smooth opening and reasonable spring tension. I'm on record all over the place in saying that I don't understand why stiff springs are seen as a virtue these days.
Spey blades are for more than just speying, they are also good for skinning small game, Making cuts in a depression or trace cutting a gasket. The 303 isn’t as much of a Spey and more like a pen but I don’t mind that cause they are almost to small for a end cutter. The 301 is much better.
I've never had the clip point or any other blade try to close on me like that.The tension on Bucks springs is only adequate to hold the blade closed and inadequate to hold the larger clip blade open. See the Victorinox Pioneer for how it should be done. Generally it doesn’t take much to hold a blade open given the direction of cut. The 301 from 2015, I have now is a replacement for one were a good flick downward would close the clip blade.
