A Small Knife I've Been Playing With
Mistwalker
I've been pretty busy lately with a lot of different projects but over the last few weeks I've been playing around with a small knife I got with thoughts on a more urbanized environment. I have this “thing” for small, tough knives that can take some abuse and also have nice sharp points. I think I've managed to take enough pictures to show the perspective from which I got the knife.
The knife is a Delta Unit 3 from TOPS knives. It's a heavy duty little tank of a knife with a flat ground 1/4” thick blade that still slices and whittles well.
The specs from the TOPS website.
O/A Length: 7 1/4"
Blade Length: 3"
Thickness: 1/4"
Steel: 1095 High Carbon
Handle: Blue/Black G-10
Blade Color: Tactical Gray
Sheath: Kydex
Weight: 14.4oz
I had seen it a few times on the website but for whatever reason thought it was larger than it really is. Actually it isn't all that large at all, and looks a bit less menacing than a black bladed knife.
I have incorporated it into a maxpedition organizer kit I put together. The kit is a modular type thing that I can carry in a pack, in a shoulder bag, or at need in a cargo pocket.
It has served well so far in all the uses I've tried it in. I like a nice sharp tip, and it worked fine for eating my snack of smoked oysters.
It came in handy when I was checking it out at dinner one night and needed to spread the goat cheese spread on my bread for my soup, and didn't cause any alarm just laying around on the table afterward.
It even came in handy when the little one thought my brat looked much more interesting than her hotdog and wanted to try a bite.
I've even used it as a mini pry bar on a couple of construction projects. Once when I was installing french doors in my mother-in-law's bedroom. I used the knife to cut the plastic banding and wrapping from the door, then used the knife as a mini pry bar when I was shimming it. Then when I was replacing our back porch steps at home and needed to pry a riser back out to trim it.
Of course I had to play with it in the woods and beat it up a bit to see how it would do in fire craft. Didn't actually do sustained fire as I really didn't have a need or the time, but I learned what I wanted to know. I used the knife to truncate a section of hardwood limb that was just barely smaller in diameter than the length of the blade, and and the flat grind sank into even very hard seasoned wood.
Then I split it down and whittled some shavings. Even in the very hard wood fine shavings for igniting with a fire steel were no problem.
I'm thinking it's a good addition to a small kit.
Thats indeed a tank! 1/4'' in that size knife is just brilliant! I like it, u have a very nice mini-kit going on right there! Enjoyed the EDC pics very much, Thank you.
What is that mini-multitool? Ive been looking for a small model to EDC.
That thing looks like a little beast. I'm not into destruction tests but I bet it could stand up to an incredible amount of abuse. Nice to see that it cuts well too. I've had some really thick small knives that were just way too much like a wedge and not a knife. But I dig this one :thumbup:
thanks for the review/pics, but I have a question: the thickness is very large for a little knife like that, no?
I thought so too, perfect for my particular needs with this kit. Thank you the kit is slowly evolving into what I need it to be.
It's one of the leathermans, not sure which model, it's just a knife and pliers.
I think it could too. I have beat on it a bit but not rally abused it all that much. I think the flat grind, high secondary bevel, and tapered tip combine to make the 1/4" thickness work really well as a knife too and not just as a sharpened pry bar. It's definitely the sharpest little pry bar I've used so far.
For my particular uses that was a lot of the point of getting the knife to start with.
if u mean that it is thicker then normally found on smaller knives, then the answer is yes. Traditionally thick stock is found on larger blades.
If u mean is it a good idea to have 1/4'' stock on a knife that size, then the answer is up to the consumer. In My Opinion the answer is Yes, if done properly which this particular knife appears to be.
after looking at Google images, I think it may be a Leatherman Freestyle.
Sounds about right. I found them on clearance at a sporting-goods store here. It was this and the one with the scissors in one pack and the wife got the one with the scissors.
knife is ok..
But man, goat cheese is amazing. Sprinkle a little bit on some grilled salmon with lemon butter sauce *Welcome to Heaven, enjoy your time, it won't ever get better than this*
Thanks for the pic's and review. I like kinves of that size also. I think it's a little thick for me but it looks like it works for you.
Your pouch is nice. But where and how do you carry it? Is it attached to your back pack? Do you carry that back pack with you everywhere?
Great review and Photos too
ALways look forward to your posts
PLEASE keep them coming
Yes, What Doc Said. Also I wonder how the Back of the knife would do scaling Bream ????
Those serrations or what ever you want to call the should to the trick.
Jeff
Aye Carumba! I thought my 1/4" Chopweiler was a little thick and that's over 7" long !!!!
I must say that it is a really nice looking knife though and you always put forward a good case for any you have !
How do you find it compared with the HEST ?
knife is ok..
Roger, the chef at Marco's, makes an amazing goat cheese spread. I'm pretty sure he used goat cheese in the beer-cheese soup he made a while back which was fantastic. It's a pity he's on a mission to never make the same soup twice for his soup of the day, they have so far all been really good and I have had to get a take-home bowl of some to have some the next day. There are several I'd love to revisit, and soup, bread, and iced tea is like $7.00.
Very nice. I enjoyed the pics and the knife. What maxpedition case is it?
Thanks Rocky. That's a Maxped organizer I got a while back. I'm going to pick up a mini and see what I can do with it too.
Yep, it's a little thick alright, but gotten from a "urban-survival" perspective that was the draw. Thick for durability and lateral strength yet having a geometry that still works well for slicing and whittling.
Great little knife but WOW look at the spine!
Yep, far from thin huh? But nice flat grind and taper for an awesome edge and point on such a thick blade :)
Do I see right? You carry an EpiPen in your Minikit?
Yeah, technically belongs to my partner because I am forever dragging his highly allergic @$$ into bee infested areas to show him something new. He leaves that one with me just for that and the fact that we don't yet know if my youngest is allergic or not. I'm not, my wife and oldest daughter aren't, but my mother was extremely allergic.
The organizer is an easily relocate-able modular core of essentials that is sometimes carried in my pack, sometimes in a shoulder bag, and sometimes in a cargo pocket depending on my needs at the time so that I can always keep that kit close by.
Great review and Photots too
Thanks Bill, glad you enjoy them. I get busy so sometimes it takes a while, but you know me, I'm ever playing around with something or some new idea :)
Jeff
Probably not very well really. They are not sharp, it's more jimping for traction of the tip of an index finger in more precision tip work.
Yeah, it's thick! But on such a small blade the mass isn't really such a weight.
Thanks man, you know me I just like to play around with all sorts of things, I figure I might as well share what I learn, the way I see it information is shared and should be helpful whether people think like me, think the opposite of me, or somewhere in between.
Well, it's thicker than the HEST and it's not skeletonized like the HEST nor does it have the notch in the blade so I expect it to be more durable but still as sharp and pointy :)
Your reviews are top notch. Thanks for sharing anther one. I'm becoming really impressed with some of TOPS latest knives.
