- Jan 21, 2008
the other day i saw misanthropists thread with his home-made stove and thought is was pretty cool. the thought of somthing that i could cook with, could heat an enclosed shelter with and could make very cheaply (not a whole lot of money to spend on a nicer one, as i only work about 5 hours a week at minimum wage) was apealing to me. so, having a 4 day weekend, i had plenty of time to get the thing built.
here are the materials i used: 2 empty paint cans ( 1 Gal), 8 nuts and bolts, a small stovepipe, and some washers. all of it cost me $13.81 from Ace.
first i drilled the holes for the bolts, then proceded to afix them to the main body.
then put on the stove pipe. i could really think of any great way to secure it, since i still wanted it to be easily removable. So, i ended up just shoving it in and opening that i cut in the back. it works well and stays on securly:
then i took it out for a spin. it worked , overall, okay. it burned VERY hot, but the way i had it set up did not really use the heat efficiently in cooking. some pics:
it really pumped out the heat, but it took an awfully long time to heat up my cider. i had a couple of modifications in mind to make it better.
more on the way!
more on the way!
