A8Mod 7 mm PushDagger, Krypton180 and others
KornalskiKnives
Feedback: +88 / =0 / -0
Hi,
You can find me on my website --> www.kornalski.com.pl
There are links to Instagram or Facebook if you use them.
Any questions; orders or want to talk mail me --> adam@kornalski.com
To all costs posted in the thread --> you need to add 5% for PayPal fee.
STEEL - AISI A8Mod (Bohler Chipper, Uddeholm Viking)
General Uddeholm Viking is a oil-air-vacuum-hardening steel which is characterized by: • good dimensional stability during heat treatment • good machinability and grindability • excellent combination of toughness and wear resistance • normal hardness in the range 52–58 HRC • ideal for surface coating (CVD, PVD) Exaggerated sketch of a typical punch and die in action. The chemical composition of Uddeholm Viking gives a hardness potential of 58 HRC with compressive strength and wear resistance accordingly. The small amount of primary carbides means a high chipping resistance and with 8 % chromium follows a very good hardenability and also a fairly good resistance to corrosion.
Typical
C Si Mn Cr Mo V analysis %
0.5 1.0 0.5 8.0 1.5 0.5
Applications Uddeholm Viking is a versatile, high alloyed tool steel characterized by the right combination of toughness and wear resistance required for heavy duty blanking and forming.
Knife: 3x PushDagger
Steel: A8Mod
Tool Steel
Thickness of 6,8 mm
Hardness: 57-58 HRC
Handle: G10 black sandblasted
Attachment: Turn black imbus screws
Finish blade: Stonewash
Size:
Total length: 180 mm
The width of the blade: 45 mm
Blade 105 mm
Weight 255 g.
Sheath: 1,5 mm black Kydex with Big TekLok
Asking: 200 $ shipped
Knife: KRYPTON170
Steel: A8Mod Tool Steel
Thickness of 6,8 mm
Hardness: 57-58 HRC
Handle: Brown canvas micarta sandblasted
Attachment: Turn black M5 imbus screws
Size:
Total length: 300 mm
The width of the blade: 38 mm
Blade 170 mm
Weight 465 g.
Sheath: 1,5 mm black Kydex with Big TEKLOK
Asking: 250 $ shipped
Knife: ODC180
Thickness of 6,8 mm
Hardness: 57-58 HRC
Handle: G10 Black sandblasted
Attachment: Turn stainless steel M5 torx screws
Size:
Total length: 280 mm
The width of the blade: 37 mm
Blade 150 mm
Weight 438 g.
Asking: 220 $ shipped
Knife: 4x AgorEDC
Steel: Vanadis 4 Extra
PM Stainless Tool Steel
Thickness of 4,7 mm
Hardness: 63 HRC Secondary hardness
Size:
Total length: 255 mm
The width of the blade: 33 mm
Blade 125 mm
Weight 219 g.
Knife I
Knife II
Knife III
Knife IV
IMPORTANT NOTE:
Bohler Stainless Steel N690 tool steel is very good steel.
But when hard is not very tough for heavy works especially with the tip.
So:
No rust, holds working edge long, easy to sharpen but not suitable for tanks or windows opening. You can loose the tip.
Perfect for kitchen, cutting, slicing or skinning.
Please consider this when buying.
J.
Knife: Agor
Steel:N690 Bohler Stainless Tool Steel
Thickness of 4,4 mm
Hardness: 58 HRC Secondary hardness
Size:
Total length: 265 mm
The width of the blade: 34 mm
Blade 140 mm
Weight 230 g.
Sheath: 2 mm black ABS with Big Tek-Lok
Asking price: 150 $ shipped
Knife: Agor
Thickness of 4,4 mm
Size:
Blade 140 mm
Weight 245 g.
Thank you for kind words.
No I have not. It will be just a neck knife then ;) with strange handle...
J.
So, this is more of a request borne of legalities, I think. At least where I've lived in the USA, double edged knives are pretty universally declared illegal for carry whereas single edged knives are not. The purpose of a push knife isn't put at a detriment by having one sharpened edge and an unsharpened swedge for example.....and would be legal for me to carry whereas if it was double edged it would not be.
May not be that way where you are at, but in the states it is something many people likely consider.
OK Do not know that. In Poland knife is the TOOL not weapon. We can carry whatever we want to. Even swords ;)
We can carry spring folders daggers....etc. But one has to be a VIP to get gun allowance.
Each country has its own laws... user has to know that for his own safety.
I can make the one edge dull ;) will not cutt anything; just the false edge or swedge as you call it.
Regards
Adam
