- Aug 22, 2006
You know what I appreciate With Busse enthusiasts?
It guys very moderate
Zaza dr sa 4a
Agreed. To my eye black canvas and patina is the toughest looking combo in all of BusseKindom.As long as it's not left wet for to extended periods it likely wont be flaking full fledged rust.. it will however begin to show a good patina...which is sexy as hell.. looks tough, looks serious
Just dont store it wet and give her a light coat of oil after use an she will be fine..
If I remember correctly, Bossman just said that it was something that happens during the manufacturing process. But the manufacturing process starts with a blank sheet of steel and ends with putting the final edge on the blade, so anything that happens in between is still a mystery. Lol!Has anyone ever gotten the scoop on what the heck those gremlin marks are from? Looks like a damn ball tipped engraving bit ran wild over the blades. If it was a cnc machine the chuck must be wobbling around like crazy or the bit bent to be so random.![]()
Zaza dr sa 4a
Ya I know...its not sr101, but it is a good shot of a busse and a cheesy pie![]()
...it looks to me an old school version, if so it will have DHT. I think the M9/M6s were the last of the DHT blades and the Weiler pre-dates them.
SR101 rusts when you look at it. Be prepared.
How is that SAR holding up? I thought about it the other day when I found a couple tiny freckles on my blasted TGLB.Not as bad as that gray stuff under the CG coating on Busse blades!
If you don't get that stuff all off, it will run in an environment controlled to low humidity. I've experienced it. One SAR5 that I couldn't sand the stuff away. It was rusting overnight inside the house with the AC running. It didn't stop until I got it bead blasted away.
Not so much my SR101 blades. I get them sanded good, and don't have a problem. In the two that I've done.
.....that is somewhat overstating it I think mate. It is a carbon steel and will oxidise like they all do, no worse than any other in my experience and if I am to be honest less than many, it also seems to stay surface bound and wipes away with a hint of an oily rag. The simplest of knife maintenance, the kind we should all undertake no matter the steel, will prevent it. In fact I just located my stripped RMD that has been behind a bike in my garage for close to the past 12 months (my garage is moist year round and humid across summer). The knife is in a kydex sheath and fell there with only minimal maintenance (not like I planned for it to be there) and it is unmolested.SR101 rusts when you look at it. Be prepared.
