Advice for rolled bowie.
I have sent a fair number of batches of 15 to 20 blades ea to Peters for heat treatment. Every blade came back with a Rc test spot which was easy to see by the buffed off area and divot from the diamond. Jess
That's been my experience as well.
I wish I could "like" your post James:thumbup:
I agree with James....there is something majorly wrong here.
It's kind of you both to say that. I'm just trying to think through the problem in a reasonable way.
Personally, I'm looking forward to hearing Josh tell us whether/how the folks at Peters' address this troublesome issue... and I remain confident that they'll figure it out. Until we hear that, any further speculation is not very helpful.
Huge bummer Jobasha to put all that work into a knife for this to happen! FWIW I just got a call from Brad the other day regarding the last batch I sent them. I erroneously put an O-1 blade in with some 440C. It wasn't hardening so he analyzed it and it came up O-1. My point being that it seems that he is trying to do a good job even if it's not his mistake. If it turns out to be a bad HT the question will be will he make it right? I would imagine he would. Jobasha have you heard from Brad? Hopefully you can get the blade figured out!
I didn't have a chance to read every post before I replied yesterday, I apologize for that. Should have just waited. :o
Btw, I think you're handling this very professionally. It's good to allow the craftsman (in this case Peters) a chance to correct a possible wrong before going any further. I think any craftsman can appreciate that.
Looking forward to seeing the outcome and I hope it goes well for both you and Brad.
Just got off the phone with brad.
Said I could send it in for steel testing to figure out whats going on:thumbup:
I talked to him earlier today. He confirmed that it was 52100 and something must have went wrong with the heat treat. He redid it and sent it back today.
Good customers service...problem found .... problem solved.
This thread is a perfect example of how the BF community can work together to solve a problem civilly and satisfactorily.
Jobasha could have been going off on a rant about how crappy Peter's was and how he was mad, ... etc. But instead he asked serious questions and got serious answers, ....all leading to a pleasant solution. I am willing to bet he uses Peter's again, and that this was a fluke. The direct and to the point replies by the folks here also made the problem's solution easier.
Kudos to all of you.
Thanks, tides could have changed very quickly in this thread. Not happy that it happened but glad it got taken care of. Sh*t happens and I can understand that (seems to happen a lot to me though:confused::o)
Josh I am sorry you had problems but thanks for sharing. Before now I just assumed that if peters treated the blade it was good to go and I have not been bothering with testing my blades that they treated. I now understand I need to test regardless of who did the HT. This thread will make me a better knifemaker. THANKS
That's weird, i assumed heat treating services would do hardness testing, but i bet it is not pratical to test all the pieces...
When it comes to performance there is a lot involved into each of the heat treatment steps, the rolling of that edge was fortunately a macroscopic event, but there are many more subdole things that may go wrong...not noticed... grain growt, carbide segregation, RA... not so easy to spot those one.
Just a comment, because I have no idea what the particular problem was....
Just because a blade hardness tests on the tang that it is Rc59 is not a guarantee that the edge is Rc59. Normally, it is pretty much the same, but strange things can happen from time to time.
