- Jan 24, 2018
Where at?A friend of mine just went and did a class.
www.instagram.com
Where at?
savagecustomknives.com
You shared it fine on my end! But oh wow, I never would've expected that to be his shop at all. Ray is an awesome maker and designer, just goes to show you don't need much to do great workUgh, I don't know how to share an Instagram post. Anyway, his shop seems to take up half of a two-car garage.
If your blanks are not yet heat treated, you probably need to leave more thickness. If your stock is thin, less than 0.08" or so, you should probably heat treat before grinding. If you grind pre-heat treat, you don't go all the way to final dimensions. Just get it "close" then stop until it is hardened and tempered.My main issue with these 3 mess ups, are not going over my center line. I'm still grinding too much over. When I cut my initial 45s and start working up, I go over the line instead of working up and back. I tend to go forward as well. I'm still trying to get my stance and movement down as far as holding the knife when grinding as well. That's causing trouble for me too
Yeah I won't have any heat treated blades until I have a lot more skill level, because I'll be sending them off when that time comes.If your blanks are not yet heat treated, you probably need to leave more thickness. If your stock is thin, less than 0.08" or so, you should probably heat treat before grinding. If you grind pre-heat treat, you don't go all the way to final dimensions. Just get it "close" then stop until it is hardened and tempered.
If you are grinding through your midline, you are doing way too much grinding. Don't apply pressure at the edge, at all. The only time you touch the edge is when you profile, or sharpen. When grinding bevels, your finger pressure needs to be in the middle of the blade, near your intended grind line, not near the tip.
Mecha , where's the coal? Or do you have to make your own charcoal too?
you killing us
Why you push freehand filing with file ? Whats the point there ?Yeah I won't have any heat treated blades until I have a lot more skill level, because I'll be sending them off when that time comes.
But thats what I need to work on for sure, because for example the last blank I ground, I hit my center line fine, then when I started walking the grind up the blade, I noticed that it wasn't really thinning out at all. Like my bevels weren't going "in", they were just going "up". They were getting higher but not thinner. If that makes sense. But I know its just all a matter of practice and time at the grinder.
Whats the point of what? I'm not freehand filing I'm freehand grinding. But I've seen the file jig method, just haven't tried it since I had the 1x30. I know it's not ideal for bevels but I wanted to start practicing and trying to get the fundamentals down. I know the process, but that's a lot easier said than done lol Anyway I might make a file jig sometime soon, been wanting to try it for a while anyway even though it takes time. I don't mind, I want to see the bevels it produces.Why you push freehand filing with file ? Whats the point there ?
This is what you need to do if you want next bevels to be prefect . Make file jig , two hours work and grind bevels .Leave edge little thicker for heat treat .Send knife to be HT . Then use some angle iron as jig and finish bevels on that 1x30 , little hand sanding after that and you are done . Works every time .One of my best knife is done with file jug ,a relaxing job, without worry that you can screw something up.
I found some picture of that knife , here on forum .....I lost them in the computer
How you make this knives ? You say somewhere that you never try file jig ?Whats the point of what? I'm not freehand filing I'm freehand grinding. But I've seen the file jig method, just haven't tried it since I had the 1x30. I know it's not ideal for bevels but I wanted to start practicing and trying to get the fundamentals down. I know the process, but that's a lot easier said than done lol Anyway I might make a file jig sometime soon, been wanting to try it for a while anyway even though it takes time. I don't mind, I want to see the bevels it produces.
That's a nice knife!
I've also attempted the old school approach and picked up some good quality files, sandpaper, vise and hacksaw and did one or two blades that way as well, but I quickly learned that I wasn't born with the patience
Thanks !That's a nice knife!
Look , I am trying to help you . Forget that freehand grinding and use file jig or jig for grinder you have and make some knives .There is no reason to waste time and steel learning something you don t need to make knife ?
That’s just my opinion , I don’t expect or ask anyone to agree/disagree with that . There are a million ways to skin a cat , everyone can choose their own way .I completely disagree
