- Jan 26, 2013
I did not talk to AKS I am looking at the ht info for different steels and aeb-l is the only one I have found that lists the aust temp as 1920 then in the decription says 1940 I assumed it is a mistake or typo?
I did air quench to room temp then into alcohol dry ice for 1 hour. Sounds now like my temp was low compared to bluntcut's sucessful ht. Maybe oil quench is better? I have a piece left, so i will try with oil quench and a higher temp for 10 min soak.
I'm assuming you are wrapping these blades in foil during HT? I would recommend the plate quench. I then put them in LN, but I think a dry ice bath is also ok for AEB-L. I've never tried oil quench on something that requires foil. Can someone make a comment on how that works with a natural atmosphere oven.
After 6h and acetone in room temp, that temper probably was pointless.
Martenzite was already setted.
No, this is incorrect. The temper is not pointless, it's necessary. Martensite does not "settle".
Dry ice is nothing to do with a temper, it is simply completing the quench. You have to temper after the quench.
