Hey guys I'm definitely not getting worked up. I know it's difficult (impossible) to infer tone or sentiment in this medium, but this is not the case.
I'm simply questioning something that I've seen repeated as dogma, with nary and explanation any time I've seen it mentioned. I know many things repeated in such a way (and lets be honest, there's a lot of people just repeating what they've heard, without knowing the why), have merit and reasons behind them. However, not all of them do, and many things get promoted as if they're the only way of doing things, and that culture has driven a lot of very competent makers away from these boards.
I'm more than happy to be wrong about something, if it can be explained why.
I agree completely that efficiency and quality are always important. Although the pragmatist in me believes that doing something quickly, which is what i think what efficiency means in the case of what we were talking about, may be arbitrary, if the result (quality) in the end is the same, and instead of investing active time in one thing, I can do something else with that time, with less direct effort (time, efficiency) and cost efficiency.
So I'm still uncertain whether I'm being told that using acetone or alcohol in dry ice is *necessary* to achieve the same results, when it comes to sub-zero quenching AEB-L (or D-2, or any other steels that need temps within the realms afforded by dry-ice alone), but I will be happy to know, and concede the answer. If it will work, and the extra step is simply idealistic process, why would the other be more recommendable unless there is some actual change to the end result? I understand that gas is a poor conductor, but even in still air temperatures will equalize, albeit slowly right? This is an issue for beating the cooling curve for austinizing, for many steels, although not all, but is this a legitimate concern for sub zero quenching these steels where dry ice temperature is effective?
I'm honestly trying to understand. Not trying to start some emotional debate.
Samuraistuart, I apologize for being snarky, I wasn't offended, it just seemed like you were piling on for no reason. As I mentioned, I don't want to promote a culture of "don't ask questions, just do what you're told" here. I know we've had some topics get out of hand where "conventional wisdom" has been questioned, but that's not my intent here. I quench in Parks, for the record.
