Diamond cutting wheel will done that job in half minute ............I ground mine a little on ceramic belt. Then into the drill press and finished with a diamond file.
That is the type of tool I used. Half a minute is a bit exaggerated, but not by much.Diamond cutting wheel will done that job in half minute ............
Cutting TC with diamond wheel is a little harder , because wheel loses quickly diamonds on edge , but for shaping they are great . I use 60mm Dia. one for sharpening drill bits with TC tip and I have to be careful because only one touch is more then enough to sharpen one side . They simple eat TCThat is the type of tool I used. Half a minute is a bit exaggerated, but not by much.
I used the same wheel to score the carbide and then snap it. I don't think it would have been possible to cut through, the diamonds wore away quickly and it quit cutting.Cutting TC with diamond wheel is a little harder , because wheel loses quickly diamonds on edge , but for shaping they are great .
It would cut , just not put pressure on disk , let the diamond to do the job ..............But they will not last long even with very light pressure .I cut lot of TC not so long ago https://bladeforums.com/threads/san-mai-with-tungsten-carbide.1746640/I used the same wheel to score the carbide and then snap it. I don't think it would have been possible to cut through, the diamonds wore away quickly and it quit cutting.
Pablo, I am about to try your method and just want to make sure I did not misunderstand you. When you say "poor HT", do you mean you quench the blades? My first interpretation was that you keep the blades at 900C for ten minutes and then lower the temperature to 650C without taking the blades out. Now, I'm not so sure anymore.It was trial and error, my idea was to do a poor HT at 850-900C and then soften the steel at 650C. What you saw with the rack was an ongoing test following some ideas from Larrin, so far so good.
650C I leave it for at least two hours and then let the batch cool inside the oven overnight.
Regarding the oven, it's still my current oven, purchased the same PID again to make a second one, probably this year. If you need help just post in that thread and I'll do my best to help you out!
Pablo
Ok, that makes sense. I also use quench plates. I guess I essentially do the same thing as you, only with slightly higher temperatures for both the pre-quench and anneal. And I did not let the blades cool in the oven after anneal, I will start doing that and see if it makes a difference.Sorry, wasn't clear enough. I don't quench stainless, I press it between plates and this is what I do, 900C>cool between plates reheat to 650C.
Here are the pics of my straightening hammer arsenal:
Pablo
Nice hammers! What does ranura mean? Google says spline or groove and I can't figure out what that might have to do with the hammer, especially since the other one says carbide.
Maybe the video below can explain it a little. The relevant section starts at about fifteen minutes.Interesting! Thanks for the pictures. SO on one hammer you grooved the hammer and inlaid carbide rod across it? So when you use that are you hammering lengthwise on the blade or from spine to edge? Sorry for all the questions.
I do this as well but I also sandwich mine together between 2 thin pieces of aluminum jig plate sheet that I tapped holes all over in one side and counterbored on other and I screw the aluminum plates together when the go into LN also. I do get some very minute warp that I can easily take out.I have had good luck clamping them between angle iron AS SOON as they are finished plate quenching. They stay clamped when they go into the dry ice slurry and temper. After the first temper I check whether they are straight or not. 99% of the time they are. After the check, I reclamp, temper again, and they stay clamped until I am ready to surface grind. Which is usually a couple days later. This is my method for Nitro-V as well.
I just did 18 knives this way. All straight. I clamped them all together between the angle iron chunks.
