Cliff Stamp
BANNED
- Oct 5, 1998
This is a small tactical/utility from Bob Dozier. The knife was used extensively for an extended period of time, by me and friends. The review is based on that, stock work, and direct comparisons against other blades.
While this knife worked well as a small utility knife, it would readily be outperformed directly by something like the Deerhunter. The Agent is ground out of thicker stock which does make it stouter, but the steel was very inflexible and the tip snapped readily during carving of a small bowl.
Personally once the steel thickens and the scope of work starts to include prying or anything harder I would look towards simpler steels, or make the knife really thick like the H1.
In regards to the performance, the NIB edge had problems with low sharpness and inconsistency of angle which lead to a complete profiling. The sheath also flattened the edge until the edge was wore down enough through repeated sharpening that it didn't make contact anymore.
There was also an extended EDC comparsion edge retention wise, plus a series of tests on cardboard vs the Safari Skinner from Swamp Rat and both were near identical on cardboard and the Skinner much more durable with respect to fracture (idential edge profiles) in general.
Before using the knives I wondered about security with the smooth grips and this was indeed an issue. With a clean handle and a fresh hand it wasn't a problem, but with any contaminant it was difficult to keep control of the grip as the retention was low and doing a hard stab simply wasn't practical.
I will be repeating the edge retention comparison with a K2 to see if it is consistent and looking at work similar to the retarded mauling of the Skinner by Eric and company in the upcoming week, ref :
http://www.bladeforums.com/forums/showthread.php?t=322561
Link :
http://www.physics.mun.ca/~sstamp/knives/agent.html
http://www.physics.mun.ca/~sstamp/knives/reviews.html
Note the K2 didn't have the initial edge problems or sheath issues as did the Agent.
-Cliff
Link :
-Cliff
