I didn't say he was "only" known for thin hollow grinds. I know he makes a variety of different types of knives. The knife in this thread is the one I was referring to. It's my opinion that a Dozier knife needs no testing. That's just how I feel. As far as Cliff testing one of mine, I wouldn't give him a wooden knife to test. I didn't want to say it, again this is my opinion, I think he's a fraud. Where are the pics of this man doing all these tests. When they field test a knife for an article in a magazine, there are pictures showing what was done. Hey if I'm wrong, I apologize, but from what I've been hearing I may not be that far off. I want to see Cliff doing these tests. Anybody can write up a review and post it on a forum. You stated in your other post Mr. Dozier and his staff are not Gods they're human. How did Mr. Stamp become such the "God" of reviews. What are his credentials? Believe me I'm not the only one who feels this way.brownshoe said:Mr. Razorback, You musn't know too much about Dozier's knives if you think he's only known for a thin hollow ground. He's known for putting out a variety of products, yes with a hollow ground, but not all are thin and many have quite robust tips.
A Buck 110 may be used as a tactical knife, but it was designed as a hunter. Cops in my family carried them in the old days, but not to pry with. They were carried becasue they were the only one handed opening blade available at the time. Also, only a rank amatuer would try to split bone with an inappropriate tool.
Again Mr. Razorback, why are Dozier knives above testing? Is that because they are custom...does that make your knives above testing too? Why not send cliff one of your blades with a paragraph on how it should be used?
I don't see the big deal. The dozier held up reasonably well; of the two problems, one is an easy fix, the other, who knows why the tip fractured. It really isn't that big of a deal. It's the most common break for any knife style.
brownshoe said:Why not give make two identical blades, give one to cliff and see what his test results are. Then, if you feel your knife did not perform as expected, do the tests yourself and see if you get the same results. That'd be a method to offer objective evidence to proof cliff didn't actually do any testing at all.
Thank you STR. Knives cut, use a maul to bust a cider block and use a crow bar to pry open a door or window. Does the knife cut well or not, what else do you need to now. Oh, gotta answer the door I think my knife field tester is here.STR said:Go ahead and buy two Dozier knives. But let me save you the time of testing them. The tips will snap if you pry with that D2 blade. So there and in a gesture of thanks you can juse send me the knife I saved. Much appreciated.
Look at what you just said, a Case sod buster. What steel is that, carbon, that's alot less brittle then D2. Study up on your steels dude. Most carbons are softer then the new supersteels. A professional wood carver would know alot more about carving with a knife then the average Joe.brownshoe said:Knives cut, true Mr. Razorback. Knives are also used in carving. A spoon carver I know uses an old case sodbuster to make $400 hand made spoons. I can't believe you would think wood carving is abuse of a tactical knife.
Cliff, take Mr. Razorback up on his offer. Buy one of his blades, test it and then send it back. He'll refund the money to you. Given the shape of his blades, you should be able to put it through some real abuse.
Get real, do you think after all this I would let him test one of my knives? He doesn't have enough money to buy one. I've got real users lined up.brownshoe said:Knives cut, true Mr. Razorback. Knives are also used in carving. A spoon carver I know uses an old case sodbuster to make $400 hand made spoons. I can't believe you would think wood carving is abuse of a tactical knife.
STR, On that folder is that a forged blade by DC in 15n20?
Great steel these Russell knives are. Not sure what it is but whatever it is it keeps an edge and sharpens up easy.
