- Nov 15, 2006
Mr Graham beat me to it.
If you are gonna' shoot PAPER, get an AR.
If you are gonna' shoot PEOPLE, get an AK.
TR Graham
The Glocksmith
Of course if you want to do both get an M-4...lol. Anyone who thinks the 5.56 round doesn't do it's job is just plain silly. I wouldn't want to get shot with either. The AR platform performs fine and is reliable.
I know everyone says the AK must be better, look at all the countries that use it. Think about that. If you are a third world country and shopping around for a rifle do you buy something that is hard to acquire, difficult (if not impossible) to manufacture yourself, and requires training to use? Of course not...you go with what can be produce cheaply and used by people who have never held a gun before. One that can be made in a cooking pot factory or even made using a coal forge by hand. The AR needs advanced technology to make, something many countries that use the AK don't possess. Add to that the US has not given the rifle away by the millions to communist sympathizers and countries that support communism and it is obvious why the AK is in use in more countries. It is a matter of availability. not a matter of being a better battle rifle.
The story about the AK-47 in the mud probably came from "About Face: The Odyssey of an American Warrior" by Colonel David H. Hackworth. If I remember correctly, they found a dead VC in the mud. The body had obviously been there some weeks. Colonel Hackworth said something like "You guys want to see a real assault rifle?", picked it up and fired it.
If you haven't read the book, you should. "Warrior" is absolutely correct!
Is there any way to know what calibre most AK models currently in the field worldwide are?
The Soviets switched to the 5.45mm over thirty years ago, right? I would think that by now most professional armies using the design are with the smaller round.
Based on the time period, I would also expect that surviving captured/abandoned Soviet rifles in Afghanistan would be 5.45mm.
When the USSR armed their allies and surrogates, after their own switch, was it with current (at the time) rifles or did they ship out the old stuff?
On the ground in the mid-east, or in Africa, what would one expect to find in the way of AK chambering?
The same 'ol song and dance. Well, High Point carbines are cheap too, but you don't see millions of them in frontline service with armies around the world. AND you missed the point. I wasn't talking about calibers. I was talking about rifles. I'd say the better "battle" rifle is the one that works when you need it to. I also want something simple, reliable and durable - so I want an AK.
I have slightly over 10 years of military experience with the M16A1/A2 rifles, and another 15 on the civilian side. I've carried them, I've shot them, I've qualified with them, I've cleaned them, I've unjammed them, I've repaired them, and I've cussed at them since I was first issued one. (an old "Hydro-Matic Division of GM" M16 - NOT an "A1".)
In that time and in the years since I learned more than a few things about the great M16 "battle rifle". Accurate? Yes, MOST of the time. They aren't always. They are also fragile, temperamental, overly complex and require a great deal of maintenance - especially when compared to an AK.
This is due to the direct gas impingement action, how they are made, and what they are made of.
Now, just how many other rifles outside of carbon copies of the AR/M16 use direct gas impingement?
I can think of a grand total of.......two.
On the other hand, how many rifles use a AK style gas piston? The list is long. Very long. Hmm....wonder why that is?
Get some dirt, mud, sand or even heavy dust into a M16 and you better clean it, especially if you want your rifle to shoot more than one round. Do you have your special toothbrush on hand? A good supply of pipe cleaners? And make sure that you dont jam a pipe cleaner into a gas key or gas tube. If it breaks off or gets stuck and you can't get it out guess what? You have just deadlined your rifle. Gas rings staggered? Don't know? Better check. Rifle may or may not work. And don't forget the lube - the M16 generally will not function without it - unless you are in the desert. Then you better have some special dry lubricant on hand. Ever "lube" a M16 with a pencil? I've had to. It worked about as well as it sounds, but it was better than skin oil - which was the other option.
And because the M16 does need more cleaning more frequently then some other rifles, small part loss can be a problem. 5 parts (extractor pin, extractor w/spring and buffer, firing pin retaining pin, cam pin and firing pin) of the 14 components that make up a field stripped M16 are either small or tiny and can be easily lost. Unit armorers get to pass out a lot of replacement parts. Ask me how I know this.....
An AK? Breaks down to 7 LARGE parts. Easy to clean, hard to lose, and easy to manipulate for reassembly. Once apart, you knock off the excess carbon with a rag and some motor oil. Run a pull-through in the barrel. Good to go. Lubes? Just about anything will work, and work well. It has been said that you can lube an AK with mud - an exaggeration, but you get the point.
So you like the M4? That's nice. To me it is just a shorter, and because it is shorter, a less effective version of what I carried during my service. The operating controls are the same. The action is the same. The problems are the same.
And the current fashion of hanging a bunch of crap on a short barreled carbine does not make it into some super "battle rifle". It DOES increase the weight, screws up the balance and makes the weapon overly complex to use and maintain. Not to mention that many of those high-tech do-dads (the Army calls 'em "force multipliers") require batteries. Crap like this I like to call "tacti-cool". Now I know you didn't mention this, but I am.
However, I'm not a stick in the mud. There is one "new" modification for the M16 I wholly approve of - gas piston uppers. (yup, works just like an AK, fancy that....)
Nope. You can keep your AR/M16/M4's. To me, they are nice, accurate, light duty range rifles that some folks make a fetish about dumping a bunch of money into.
I want an AK. It does not need to be surgically clean to work. It doesn't require special cleaning equipment or lubes. It breaks down into 7 large, easy to clean and hard to lose parts. It is simple to use. In the hands of a skilled rifleman, it is a hell of a lot more accurate than most people give it credit for. And yes, it's chambered in a good caliber.
To me, that makes the AK the better "battle rifle".
TR Graham
The Glocksmith
Yeah, but the loss of velocity renders the entire design into a purty .22. That makes me want to go the Marine route and stick to a proper barrel length.as far as "why would anyone want a short bbl M4"?
because they are lite, handy, look cool & spec-ops guys carry 'em, & i suppose some folks really need 'em ie armor crews, air assault guys who need something shorter than a std rifle.
Obviously with the military expectations for all conflicts to go to the cities, requires shorter barrels means we need to drop the M-16 in .223. It was a good run but it is time for something else. Might as well drop the whole platform and go back to a piston driven weapon. It worked spectacularily in WWII; no reason to re-invent the wheel, just make it rounder.
Hopefully they would pick 6.5 Grendel but they will probably pick the inferior 6.8 Rem SPC due to market interests.
There is not that much velocity drop, especially with proper ammo that utilizes a fast powder, most definitely not .22RF class. My shorty chronograph testing show only about a 120 fps drop on average. My shorty has a 12 1/2 inch barrel rather than the 14 1/2 the M4 has.
(normally it wears a dot but I had been doing some ammo testing and wanted a scope for accuracy off the bench)
If there was no need the 6.8 SPC and the 6.5 Grendel wouldn't be competing for the tap.
Another problem the 124 grain 7.62 has already solved.
