- Dec 6, 2013
Have a bunch up for trade today
All trades must be properly pkgd and insured, i'll do the same
If you have low(er) feedback, you'll be asked to ship first
Pics won't load, i can send you pics via email, which means i'll need your email address
Pls include pics with any offers you make.
Email is the better way to reach me
USA only pls unles we've business together before
Looking for(in no particular order):
Busse and kin-bigger the better
Ferum Forge
Strider smf's and fixed no s30v or cpm-154
Les George Fixed and folders
Spydercos- Collabs and sprints mostly
Benchmade folders- no s30 or 154cm
ZT Folders- no s30v or s35v
CRK Folders
Sniper Bladeworks folders
Nocturnal knives- Folders and fixed
Elishewitz Folders-custom and midtech
Fixed and folders in : 3v, 4v, m390, 20cv, 10v and the like
Custom and high end Tomahawks and axes
Miller Bros Blades-Bigger the better
2. Swamprat RMD Proto 1 of 13- 5 1/4" green ceramic blade with black paper scales. Unused, uncarried and unsharpened. Comes with a armorall leather sheath for a Busse SJTAC. Not the best fit, but it does work
3. Busse SOB Trailing(Clip) point- Comp finish blade, Black and Brown G10, looks like brown and dark blue. Unused, uncarried and unsharpened-
4. Scrapyard Infi-Hack 1 of 12- Satin blade, Resiprene C handles. Unused, uncarried and unsharpened. Has some marks on the blade from not having the inclusions fully buffed out-
5. Ti Nives Stars and Stripes Forever #51- 3.5" satin blade, 7.5"OAL. . button lock. No play in any direction, blade is very slightly off centered. Opens smoothly and easily, closes under it's own weight. Comes with case-
6.Cold Steel Ti lite- Aus 8 blade, zytel scales. Has not been used, carried or sharpened. Blade is centered, no play. Comes with box and bubble baggie-
7.Cold Steel Triple action-Vg1 steel, double edged. Frame is aluminum, lots of scratches due to handling. Has not been carried, sharpened or used. Extremely sharp. Comes with correct box, baggie and warning note-
8. Randall #1-7- Stainless Blade, Stacked leather handle. Duraluminium butt. IIRC, this one was made in the late '70's or early 80's. Excellent condition, two light scratches are all i can find on it. Comes with correct leather sheath w/ sharpening stone
9. Kit Carson Sm m16- 3" Stellite blade, combo edge. Ti scales, steel(i believe) lockbar insert. I've carried it three times, not used or sharpened it.No blade play in any direction, centered and smooth.
As most know, Mr. Carson passed away in the last few months. He didn't used stellite in many of his blades, this one will go up in value and desirability-
10. Crawford Hawkbill liftlock- 3.5" matte finish hawkbill blade. Frame is one piece of 440c, 1/4" thick, milled out. Extremely sharp, no side to side play, little play up(back), but it's a self defense tool, so the hawkbill is made with a little give so that when it cuts, it acts like a claw. Have carried for two days, few snail trails, nothing big. Only negative is that someone tried to adjust(?), move or switch the thumbstud, it shows marring on the lug-
11.Rmok specs:
CPM S30V stainless steel fighter/combat hand sanded to 400 grit
.220" thick
5 7/8" blade
4 3/4" handle
handle material is double layered brick red and black G10
Professionally heat treated by Peters Heat treating to RC60
Cryo treated to -300 degrees fahrenheit
Will come with custom heavy duty hand stitched leather sheath.
12. Rmok specs:
CPM S30V stainless steel fighter/combat knife stone washed finish
.220" thick
6 1/4" blade
5" handle
handle material is double layered black and OD green G10
professionally heat treated by Peters to RC 60 cryo to -300 degrees
will come with custom hand stitched heavy duty leather sheath
13. Mel Pardue Auto- 3.75" hand rubbed blade. Red micarta linerless frame. One of the lightest blade i've handled. Few marks on the blade that i caught in pics(can send more pics to serious buyer). Has not been carried, used or sharpened-
14. Fairall Model #3- 3.75" hand rubbed s30v blade. Swedge has 1/4"ish sharpened at the tip. Tan and blue g10 scales, comes with a set of cocobolo scales too. Has extra hardware too.
Detent is on the lighter side. Requires a firm push of the thumb or flick of wrist to open via the flipper tab. It can also be opened with the dual thumb studs. Has been carried 4 times, cut arm hair to test the blade after i sharpened it. Fairall no longer makes knives, so this is definitely a collectible. Comes with soft carry case-
15. Crawford Shark 4"- Bead blasted blade, anodized ti frame with ti spacer. I've not carried, used or sharpened. Looks to have been carried lightly by previous owner. Very slight smoothing and a few snail trails on the frame. Very smooth opening. Solid lockup, no vertical play, very slight play(almost flex) side to side. 95% condition-
Link to my other trade thread: http://www.bladeforums.com/forums/showthread.php/1350394-Spyderench-T01PS-and-Maxpedition-Excelsa
Ferum Forge
CRK Folders
11.Rmok specs:
.220" thick
5 7/8" blade
4 3/4" handle
12. Rmok specs:
.220" thick
6 1/4" blade
5" handle
