All sorts
Feedback: +217 / =0 / -0
Have a bunch for trade today.
If you have less than 20 selling or trading feedbacks, you'll ship first
Trade must be well packed, have tracking and insurance
I reserve the right to deal with whomever i choose
Cash can go either way
1. Matt Cucchiara Dorado stage 2- Vg10 blade, handles are blue ano w/ gold undertones, has stage 2 "Bubble Pattern". Has been used, carried and sharpened lightly. Silky smooth flipper, no side to side play, if you fire it softly, sometimes you can get a very little amount of up and down movement. Blade is centered
Trade interests: Other mid techs, spyderco sprints, ZT limited editions, Ferrum Forge
2. Matthew Cody Hawkbill- 3 1/4" stonewashed 3v blade. Scales are coyote brown g10, liners are ti. Has been carried and lightly used. No blade play in any direction. Snaps open via thumbstud, blade stock is .15" or so. Blade is centered.
Trade interests: Other customs in same price range, midtechs, ZT limited editions and Ferrum forge
3. Spyderco Native 5 2013 #087v- Satin s110v blade, scales are diamond cut green g10. Carried lightly, not used or sharpened. No play, centered blade. Comes with correct box.
Trade interests: Spyderco folders and sprints, ZT's in cts-204p, m390
4.Chameleon #258- Made 4/96. AEB-l blade, not the ats-34 or similar blade. Fired hard, opens smoothly manually. Has been carried about 20 times, never cut or sharpened it. Has a little side to side play, i don't have the proper bit to tighten the pivot. No play when fired in auto mode. Only wear is on the lockside of the blade has a rub mark and the clip has some wear. Blade is centered. Comes with correct box, baggie, lanyard and info sheet GONE
5. Tank knives- 4.25" 1095, 1/4" thick. Handles are distressed ti. Monster blade. Weighs over a pound, but can be flicked open easily using the thumbstuds. No blade play, solid lockup, no stick. Comes with huge skull bead shown in pics. Clip is attached by one heavy duty screw that's easy to remove. Lanyard is attached to the clip so in one easy motion you can pull the clip and the lanyard-
6. Fairall Model #3- 3.75" hand rubbed s30v blade. Swedge has 1/4"ish sharpened at the tip. Tan and blue g10 scales, comes with a set of cocobolo scales too. Has extra hardware too.
Detent is on the lighter side. Requires a firm push of the thumb or flick of wrist to open via the flipper tab. It can also be opened with the dual thumb studs. Has been carried 4 times, cut arm hair to test the blade after i sharpened it. Fairall no longer makes knives, so this is definitely a collectible. Comes with soft carry case
