Zieg, if you would like to meet up in Elizabeth, I have a 110 clip point in S30V and a 110 drop point in 420HC. The drop point is not a user but the S30V is and you could take it for a trial. Seeing the drop point in person may help with your decision making. Preston
Why not carry the one you like best?I have three buck 110s. One clip point in 440C, one clip point in 420HC, and one drop point in s30v. I like the drop point in s30v the best, but I carry the clip point in 440C.
O.B.
S30v is a better steel than 440C. I like the drop point blade shape better. The tip on my drop point blade is sharper than I ever remember the tip being on the 440C clip point. (Not that that really matters for the way I use the knives.) The Blade locks up good and solid, and the action is nice and smooth. The orange wood handle scales look good with the nickle silver bolsters.Why not carry the one you like best?
Zieg
If you tell them to only fix the lock, that's what they will do. If you emailed Jeff Hubbard, my bet is, he would see to it the knife was done just as you wanted it. Then you would have you old buddy back in working order. PrestonYes. But if they fixed anything else. Like polished out the dings in the bolsters, or even just polished the bolsters shiny, or replace a cracked scale. In general make it look new like the pictures I see back from the spa treatment. It would feel like they killed it.
O.B.
Great post! Thanks for this.S30v is a better steel than 440C. I like the drop point blade shape better. The tip on my drop point blade is sharper than I ever remember the tip being on the 440C clip point. (Not that that really matters for the way I use the knives.) The Blade locks up good and solid, and the action is nice and smooth. The orange wood handle scales look good with the nickle silver bolsters.
The old two dot on the other hand. The lock is worn out. It takes about the same pressure, on the back of the blade, to defeat it, as it does to defeat the spring on your average slip joint. The blade shows a fare amount of sharpening wear. The bolsters are gouged and pitted. The ebony wood scales have cracks. There is no question that the s30v drop point knife, is the better knife. It would make sense to carry it, and I did for a while. If I was buying my first 110 and could choose between the two, I would pick the s30v drop point 100 times out of 100.
BUT, Me and the old two dot, we go back a long ways. I bought it new in 1975 for $22. For the next 20 years it was on my belt every day. It started life as a square frame. If you notice in the picture the bolsters are almost as rounded as the newer knife. That is from going in and out of the leather sheath many, many times. We have worn a hole through at least three sheaths. One day, when I crashed my bike, we went for a 100 foot slide on the pavement. We both got road rash. Mine was on my knee and took six weeks to heal. The knife's was on the rear bolster back by the lock bar. It's mostly polished off now by years of wear, but if you know where to look, you can see traces. Those wear marks and ding on the handle. It was my use that put them there, and I used the knife a lot. The knife deserves to be retired, and I thought I had retired it. I had the new knife. I think it's steel is better. I like it's blade shape better. It's lock can be trusted. Then one day I dropped the old two dot into the sheath. Just for old times sake. "Just for one day" Well? One really shouldn't trust the lock anyway, should they?
O.B.
