Chopping the upper end of a seasoned birch log without any support other than that which may be provided by the hand and thigh. Note that there's a good deal of energy loss when chopping a relatively unsupported piece of wood in this manner since the log is fairly free to pivot and bounce around under the force of the chopping. When cutting unsupported wood with a machete it is paramount to avoid binding since it can be difficult to withdraw a stuck blade--the workpiece will simply want to rotate rather than let go of the blade. The curvature of the belly on the primary edge is well suited for this task, as it facilitates a slight draw-cut (like a pulling slice) which causes the blade to pull through the cut instead of becoming stuck. When repositioning the wood it is sometimes desirable, however, to deliberately allow a gentle bind for manipulation of the workpiece before continuing--just don't get it really jammed in there!
Using the Baryonyx Machete to knock down some vegetation and stemmy growth along a slope. The back hook of the machete works well as a grass hook to quickly crop grasses close to the ground and neatly slice through woody stems. Due to the smaller size of the Baryonyx hook relative to that of a grass hook, a quick and light "scratching" motion is used to nibble through the growth. Use a low, wide stance to prevent strain on the back, and grasp hanks of the grass with the off hand to tension the vegetation and expose the base of the plants before nibbling through with the hook.
