Jim March
- Oct 7, 1998
Guys, let me start by saying I like your company. I know there's a need for good, defense-capable folders for people not yet flush with money but with the good sense not to buy mainland Chinese knock-offs or Pakistani "knife like objects".
I'm here to ask you to abandon the linerlock, and suggest an alternative.
Why ditch the linerlock?
Basically, they can fail in three different ways:
1) Impact, often to the spine, can jar the release loose.
2) Torque can cause the lock to slip.
3) The user's own finger flesh can trip the lock release. Operating under an "adrenalin dump" the user can "white knuckle" the blade, causing the lock to release. Per one source here on BF, later editions of the KFF had the release tab shaved deeper into the grip body, making such an accident less likely however gloves, or someone with particularly large fingers, might still cause such a release.
Why the LAWKS isn't a total solution.
In a sudden violent encounter, fine motor control suffers. Police across America have been shifting to DA semi-auto handguns that don't need any external switch other than the trigger to operate. They are "grab and go". The Glock is the best-known example but other companies such as Beretta and S&W duplicate that basic operating drill.
When cops do carry guns with safety switches such as the Colt 1911 family, a common modification is to remove the 1/2" by 3/16" safety switch and put in an "extended" switch up to an inch long.
Yet to fully deploy the KFF or similar pieces, the user is expected to trip a lever that measures 1/8th of an inch across.
I'm unimpressed. I have many friends on BF; some ask me questions about defensive firearms. I would never advise them to carry a gun such as a Davis or Lorcin that have a 1/8th of an inch across safety...and I'm loath to advise the carry of a knife similarly equipped.
So what's the answer?
An old lock design whose patent period has long since run out and is the direct ancestor of the William & Henry Axis lock: the Bolt Action, originally by Blackie Collins.
It could easily be adapted to something similar to the current KFF; using your current CNC manufacturing it would be inexpensive to produce and royalty-free.
If you can get the REKAT Rolling Lock at a decent price, that's another possibility of course...but I'd be willing to bet the Bolt could be done at the same price-point you're currently doing the KFF at.
Gerber still does some Bolt-lock knives to this day, the weird "finger-ring-folder" Chameleons:
http://www.gerberblades.com/gerberlegendaryblades.html?06435
The lock release on a bolt isn't ambi; it works much like the operating drill on a REKAT Roller. The REKAT lock is probably a bit stronger but the Bolt has a good history in use since the Parabellum, the first truly modern folder in my opinion and still a fine piece. I've seen a Para that went through 10+ years of daily carry and hard snapopens and was still rock solid.
In short, I'm asking you to provide a solid, reliable, daily-carry defensive folder that any 18-yr-old can afford. I believe that self defense is a basic human right and until we can truly fix the gun control disaster in this country, there's a huge market for such a critter.
Thank you for listening,
Jim March
Plankholder moderator, Community and Politics forums
Webmaster, Equal Rights for CCW Home Page
http://www.ninehundred.com/~equalccw
Lead Plaintiff, March vs. Rupf et al, Federal District court, NorCal (regarding abuse of the Carry Concealed Weapons statutes in Calif.)
Jim March
