Andrew Demko Custom American Lawman is AWESOME!!!!!
Woah, ballsy choice of materials... and full flat grind too. Sweet. Will be looking out for that one! :thumbup:
Not to mess with yr head, but you might want to reconsider a 4 inch blade. The knife is quite heavy in its standard config.
Heavier than a ZT 0301? I think it might be worth the weight given that sub 3.5" blades and I don't get along very well outside of my William Henry knives. Plus you know, I more or less settled on Desert Ironwood because it's a dense and heavy wood. Should be all right though, ever since I switched from cheap Made in China leather belts over to a Maxpedition Liger Gun Belt I haven't needed to replace my belt every 2 months:thumbup:(going on 8 months and counting).
The blade on the normal one is over 3,5 inches in length. Not sure of the actual weight but its pretty heavy. ;)
I'll certainly look forward to having my pants drop down to the floor every time I need to do my business;). Funny enough that it hasn't happened given that my EDC consists of a wallet, iPhone, cutting glove, earbuds, keys, 3 folders, 2 fixed blades, and 2 flashlights(one is a slim Quark AA, the other is a custom Surefire 6P with a solid copper heatsink).
Sounds like weight is not an issue for you. :D BTW I checked and the blade length is, in fact, exactly 3,5 inches on the standard one, so my mistake. Mine has thin liners (1mm) and a Ti backspacer but it feels to me like most of the weight comes from that fat blade (mine is 4mms).
I suspect weight isn't an issue unless the blade length surpasses a certain point. There's only so much material you can cram into a given volume of space. The only thing I don't know thus far is the thickness of the blade/handles, but I suspect the blade won't weigh too much with a FFG. Still, my Buck 110 is pretty much a solid mass of steel and nickel, so I'm not sure much else would impress me at this point unless someone uses tungsten carbide as a handle material:thumbup:.
