.......thiswas the grinder vibrating a bit first??? if the wheel is out of round or not centered on the flanges then it'll bounce and float on the metal instead of making a smooth cut... this vibration can also cause the lock nut to work it's way off... the light, thin disks don't cause as much vibration as a big wheel so it may not be as noticable...
.......this
Also, were you laying it flat on your stock instead of angling it and using the edge of the wheel to do the cutting? laying it flat like a surface grinder will put stress on your locking nut and the center of the disk not to mention try to throw the wheel in two directions at once. Not to imply that you were but its worth asking.
The question that hasn't been asked... What brand and model angle grinder are you using? Some brands have a lock nut that is reversible depending on the disk being used.
I agree with Jim, that sure sounds like the cutting disc is not held tightly (even if the nut is tight). I bet if you tried a thicker disc with the way you're presently setting the disc on and tightening the nut it would work. The cutting discs are too thin to be held properly that way though. When the disc gets stuck and stops for a second it's probably slipping. The vibrating like it was about to self destruct is from the disc being knocked off center (or part broken off, thus out of balance.) Confirm your nut is in the correct orientation (flip it over), make sure your disc is centered and there is no play between the arbor and disc's hole.No I don't think the grinder was vibrating at first. I put on a grinding disc that came with it and both felt about the same before hitting the steel. When I went to cut the steel the blade would get stuck and stop for a second. After that it would vibrate like it was about to self destruct. The lock nut didn't feel loose at all and I still needed to use the key to remove it.
NOTE: If the wheel spins after the clamp
nut is tightened, check the orientation of the
threaded clamp nut. If a thin wheel is installed
with the pilot on the clamp nut against the
wheel, it will spin because the height of the
pilot prevents the clamp nut from holding the
wheel.
