- Nov 6, 2011
Beautiful knife, Mr. Grimsmo!
No problem. I had huge problems with shattering endmills too until I bought the Gwizard calculator, it's AMAZING! Google it, well worth the $65/yr subscription, I don't break endmills anymore, at least not through normal use. The hardest operation when making these handles is profiling around the outside, it's 1/8" thick aluminum, and I used to step down 0.025" and feed at 20ipm at 4500rpm using a 4 flute regular length endmill. Even with flood coolant this would often cause chips to clog and the endmill would snap. My new method, thanks to Gwizard and my own tinkering for endmill choice, is to use an 1/8" carbide stub mill (only 1/4" LOC!) 2 flute (although I'm tempted to try 4fl and double my feedrate), full depth of cut at 0.135", 4.5 IPM 4500rpm. This works incredibly well. The chips don't clog because it's doing a full DOC so it's not re-cutting any chips. Cycle time is faster too, surprisingly. I usually leave 0.005" wall clearance and buzz that off with 15ipm, though I think I need to step it up to 0.010 or 0.015 cause I'm getting some chatter still. Hope that geek talk made sense and helped!thanks for the video![]()
mind if i ask your feed rate and milling cutter material type?? i always have such bad luck with shattering the cutters i use lol
Aluminum wouldn't be good for a pocket clip, it's too soft and bendy and has very very little spring retention. Steel, titanium or even carbon fiber work much better.Not a low ride clip in anodized aluminum.
Carbon fiber scales for the Military would be wonderful. G10 is a bit heavy.
My M4 Military could loose some weight (G11 is pretty heavy)
Love the CF scales on the Manix2. How much do those run?
GREAT work. Very impressive.
Is CF noticeably lighter than G10? I really don't know. But yes, it would look awesome for sure. I might do Military scales by the summer, we'll see.Carbon fiber scales for the Military would be wonderful. G10 is a bit heavy.
Unfortunately, not possible. The nested liners prevent me from using that material for the Para2. An inlay of glow into aluminum scales *might* be possible but it would be a lot of extra work.My woman is demanding moonglow scales for her next Para 2. Is that on the agenda?
I forget the rules on BF, not sure if I'm allowed to post prices in threads like this. But I might have updated a certain website where those prices might or might not be available....Love the CF scales on the Manix2. How much do those run? GREAT work. Very impressive.
I think you will reach a broader market at more attractive prices with G10.
I am going to courteously and respectfully disagree with NoFair. I have CF and G10 Military variants and I can only tell the difference using a good scale - not in the hand. As a disadvantage of CF (having recently bought new supplies of both CF and G10 for my personal projects), CF is very noticeably more expensive. I think you will reach a broader market at more attractive prices with G10.
On a Millie it is a 11g weight difference between the CF and G10 (about 10%).
CF is more expensive to buy, but I think G10/G11 is harder on cutting tools. So for a smaller maker the difference in price might not be as large.
