....I may be the only one in this camp - but a bolo is for cutting vegetation that is still green like tall grasses & sugar cane, vines and brush - not chopping dried out knotty 4x4's laying static on the ground....
edit ^^ i should have pressed enter sooner, but glad im not the only one to see it that way
I'm Filipino/Samoan and I know what a bolo is. A bolo machete would do as you describe but a bolo shaped chopper that thick shouldnt fail like that
I'm going to disagree with most of you. That is a very hard, dry piece of wood. The chip out has the classic signature of a blade edge being torqued laterally by a change in wood grain. You can see those same forces in the bends near the half-moon chip.
Chopping green wood with green knots is completely different from chopping into a piece of wood that hard. If you notice, none of those knives did a decent job of chopping. The wood was very hard, the wood was not supported properly and the chopper's technique was poor.
From what I saw, heat treat -- or grinding damage to the heat treat -- is not likely to be the problem. The problem is the hard knot in a hard piece of wood with a grain pattern that put lateral forces on the steel edge.
That's a 5160 your talking about. Bill Siegles 5160 wouldn't do that. Btw did u see the Bk9 destroy the other knot with ease?
^Right on^ ... A bolo is for cutting vegetation that is still green like tall grasses & sugar cane, vines and brush - not chopping dried out knotty 2x4's laying static on the ground....
The knife is covered under warranty, and will be fixed the way they do under their warranty.
That's really the end of that.
Busse would have replaced that! how are you going to re-grind a bad temper knife? also it wont have any belly....that's pathetic
The lack of belly could be annoying, but it looks like that's how it's done.
Busse is a different company, and their warranty is different.
The edge will be the part affected by over-grinding; the rest of the steel will be fine. Hence, grinding away the affected steel corrects that issue (as long as it is not over-heated by the regrind).
They will likely grind a more obtuse angle than there was originally, given that they know the type of use the owner intends.
as far as i know the knife isn't deferentially heat treated. so i would assume if the whole blade is compromised.
They grind the blade after heat treating.
This means that the thinnest part of the blade--the edge--is susceptible to being over-heated during the grinding process.
This can affect...the edge.
The rest of steel stays fine, as it's of a thickness enough to NOT be affected by the overheating of the edge.
It has nothing to do with differential hardening or anything of that sort.
+1
An enlightened Forum Member. :thumbup::thumbup:
Big Mike
i guess bark river knives can't handles any type of hard wood even to a small knot. hard woods and baby knots are their kryptonite
