BluntCut MetalWorks
- Apr 28, 2012
OK then, it would works however 2 segments ramp probably has lower temperature gradient from front to back.Thanks for all the feedback. I can most likely try most of this without any real negative impact.
Regarding
*1- I don't put blades in when it first shows 1975, but only once it is sitting at that temp without any real swings in temperature. This occurs about 20-30 minutes after the oven hits 1975 for the first time. I assume that the temperature holds consistently once the bricks are fully soaked.
Please hardness test this cracked blade to see whether finishing and aging increase its hrc. When I post-ht grind 0.05 to full thickness blades, often I do 2x 30 minutes temper again - as insurance against left over RA in middle of cross section after initial 2x temper cycles.*6- The heat treated blank sat on my bench fore 2-3 weeks before I finished it.
When a blade crack while sitting around - a simplest reasonable cause is ra to mart aging.
Btw - NJSB got NitroV from Lohmann (Germany), also same company produces Niolox.
