- Oct 17, 2007
That looks like wheel runout to me. If you slow down the table speed (not crossfeed) does the pattern change? Not sure if that's what you meant from what you've tried. I could see it being related to the serrated wheel too, have you tried lower belt tension? Could the belt be conforming to the serrations enough that it's actually presenting a faceted wheel to the work surface?
I put a dial indicator on my spindle once upon a time and got almost zero run-out, so I really don't think it's the bearings. I also dressed my contact wheel, so theoretically that should be ok as well.
You might be on to something with the belt tension, though I recently increased it and it seemed to get a little finer, especially with spark out.
This is kind of just one of those things I've been living with, as a little bit of hand sanding or cleaning up on a flat platen will take the pattern out pretty quick, but I would like to get to the bottom of it eventually.
I'll have to play around with it some more when I get time, and see if I can get some sample blocks to compare with different feeds, speeds, tensions, etc...
