- Dec 30, 2000
Yup, that's the same problem I and lots of other people have.
I just gave the example above to show wht the grip safety is supposed to do.
The fellow who had the accident no longer has such a light trigger pull, and his pistols are series 80, these days.
Andy
Hey, Andy!
I won't hold your being an actual lawyer against you, even though some here can't comprehend that you actually are one.
Anyway . . . the accident you describe probably had little to do with the grip safety. I don't think you specified, but I'll bet that when it hit the ground, the hammer dropped, causing the discharge. The grip safety only blocks the movement of the trigger (as you know), and wouldn't have prevented that. It also sounds like the hammer was about to start following in the near future, as they should not drop just because the gun hits the ground.
As far as the liability issue goes, I think it's good that Mr. Ayoob pulls us all in that direction because without his zeal, too many of us would never consider civil liability at all. The real world civil liability obviously varies based on location and the stupidity of the local jury pool, but someo people are too focused on it to the point of hysteria.
I agree that a grip safety would only be an issue in most jurisdictions if the owner did not intend to fire the gun. If the shot was fired intentionally, it's a non-issue (unless the defense attorney is a moron).
The same is true for various firing pin blocks on 1911s, whether the Series 80 style or the Swartz style. Neither is necessary for a gun that is in proper working order (which includes proper, adequate hammer/sear engagement so that the hammer does not drop just from a minor impact). Both styles can and have induced failures to fire, so I prefer 1911-style guns that do not have them to start. I think they are redundant and far more likely to prevent proper function than they are to prevent an accidental discharge.
