- Aug 2, 2010
I've recently been looking around to buy a disc sander (because I can't afford a disc grinder). I was looking for them in 9" so I can use rhyno wet sandpaper with the 3M feathering adhesive and all that. The closest size I could find were 10" and then there are the 12" ones, and then the smaller ones. I found 9" belt/disc combos, but that's the last thing need, I already have a 4x36X6 skil anyway that I rarely use. I want to use the disc for obvious things like flattening scales, tangs and guards etc., tapering tangs, and maybe even grinding in clips using th work rest as well as flattening bevels, (I know a normal disc sansder wouldn't be ideal for the last two things though since they are reversable). I'm just curious if anybody here has a disc "sander" (not grinder) that they use a lot and really like the quality, and perhaps flexability of. I can't afford a disc grinder, so I want the next best thing. I know I could source the motor vfd etc. for not as much as buying a plug n play disc grinder, but I honestly don't want go through all that, I'm not good at wiring or that great at tinkering, plus I want to be abe to use one right away, and the other major thing is that I want a work rest that is adjustable.
So if you guys could recommend any quality disc sander that you use, have used, or know of, or even any creative ways you have improved upon the ones you use, that would be great
Thanks a bunch in advance!
-Paul
My Channel Lsubslimed
-Paul
