VFD Variable Speed made simple
Step pulleys are not as cheap as you may think
Maska steel pulleys are good, plus shaft, bearings, belt
It all adds up to 1/2 the price of a sealed class NEMA 4 VFD like a KB Electronics KBAC-27D
I like direct drive with no belts, a VFD and 3 phase motor for about $200 over the price of the step pulleys with fine instant control.
NEMA 1 VFD’s will keep your fingers out, but the metallic dust intrusion will smoke it.
Motor
3 phase 220v 1.5 HP motor, TEFC, frame 56 or 56C,
RPM is up to you some use 1700 RPM at double speed.
Make sure it has a footed base for the KMG and NWG, or a C flange face mount for Bader, Bee, Wilton and GIB styles.
I get them on ebay, even with paying $100 for shipping to Canada I save $ on used motors
The 1.5 HP combination is the most common
It allows you to plug into any 110vac, 15 amp outlet.
A 2 HP motor requires a 220vac input.
VFD
KBAC-27D
http://www.kbelectronics.com/Variable_Speed_AC_Drives_Inverters/AC_Drives_NEMA_4X.html
http://www.kbelectronics.com/manuals/kbda_manual.pdf
Use the Distributor Locator to find a local source, online sources may be cheaper.
There are cheaper units, but the only VFD I have found that runs a 1.5 HP motor on a 110v 15 amp input is the KBAC-27D
It is NEMA 4, sealed from metal dust
Good community and company support, manuals, hook-up diagrams, photos and settings.
If you buy a bargain vfd, you're stuck with a chinglish manual and ridiculous programming.
Travis W reports running a 2 HP on a 110v circuit, but I haven’t tried it.
Hookup is simple
http://www.beaumontmetalworks.com/VS-setup.html
