To better answer your question in the original post, I think serrated edges would be the only draw back I can imagine.
I don't see a picture richard thurman, is it in another thread? OOPS - found it post #33. Looks pretty benign, but great fro touch-ups I'd bet.
You an put a heck of an edge on a knife using sandpaper. I convexed the edge of my Military using sandpaper and leather.
I don't have a knife sharpener, but I do have various increasing grits of sandpaper. Are there any drawbacks to using them for blade sharpening? I fully intend to practice with my kitchen knives before going to my carry knives. I was thinking of getting one of those old rubber/foam mousepads and putting the sandpaper on those.
Recurves might be a problem.
I've been working on a stripped & convexed Izula all day off & on and I can't get the stupid thing (I'm the dolt not the knife) to slice more than an inch of paper w/o hanging up and that was with the Sharpmaker.
I've gone from 200 through 800 grit then stropped. Then I but it on the Sharpmaker and did a 30* followed by a 40* micro bevel & stropped. No dice.
Tried two different cutlery steel rods, free handed on a course/medium stone then to ceramic then stropped. No dice. Finally went to a pull through sharpener, re-sandpapered and stropped. No dice.
So, a few minutes ago I go to cut a slice of copy paper and it slides across the top and bends it over. I threw it in the box next to me in disgust - I'm thoroughly vexed right now!!![]()
You are going from a convex to a stone? That's pointless as a convex edge has no degree, as it's circular. Going to a stron will either dull the edge or remove the radius from the circle give you you a dull, and weird look edge.I've been working on a stripped & convexed Izula all day off & on and I can't get the stupid thing (I'm the dolt not the knife) to slice more than an inch of paper w/o hanging up and that was with the Sharpmaker.
BE GENTAL! give it a few passes then on to the next finer grit, and so on until you finish on your strop. -If you want a super tiny micro-bevel just tip the blade up slightly higher on your final stroping, but still keep the pressure light.
Okay BryFry, I've been doing it with a LOT of pressure. Also, I do circular rotations. Should I be using the sandpaper like a strop?
chococrazy, I know buddy but I get po'ed and end up putting a working edge on it with my sharpmaker or a flat stone that I have.
Later, I try again with renewed enthusiasm!![]()
Maybe it's different in Michigan, but I can't find 2K grit sandpaper around here. If I could, I'd probably have to agree with your statement.
+1 this has been my experience too.This will give you a very good learning tool for sharpening basics, and then down the road, you may want to experement with other styles of sharpening
