- Jun 10, 2011
Sorry can't help on angles, I always just follow the factory bevel with the sharpie trick, and then adjust it up to about 3/8-1/2" from the top of the adjustment rod for the microbevel. (I believe it's about 10-15 degrees higher)
I sharpen the main bevel to a mirror polish and then use the 1000 grit stone for the micro. I can't quite push cut toilet paper when done but it leaves and edge that stays working sharp, push cuts newspaper. Stays working sharp depending on use for weeks/months. Then a few passes on the 1000 grit and it's back. Touchups take about 10 seconds, it takes longer to move the EP off the shelf and put water on the stone.
