The oil cannot get between the layers unless it is improperly made. Oil will however (IMO) break down the molecules at the surface and make the lines irregular. The whole reason for Damascus is to give the blade superior stain resistance. They did that so you dont have to put anything on the blade to protect it. I'm very careful what i do to an expensive blade (even when i use it, but use it i will even if it messes up the blade cause that is what it is made for).
And that says it all!
Bill
First of all it is not all steel, nickel is not steel.
Steel also has molecules like almost everything else.
Bridgestone laminated chrome over their pistons and the chrome wont stick, because the oil can work its way between the laminate!
Splitting hairs there. Can you prove 1095 has more than a trace amount of nickel. Maybe all substances have nickel in them. Maybe all substances have iron in them too, ad. infinitum.Steel is not a pure elemental substance, it is an alloy of iron, nickel can be one of the alloying elements. There are many steels which are extremely high in nickel. As well not all damascus even has an nickel in it.
Perhaps your a rocket scientist. My hats off to you maybe. What you are saying is that a grain of steel is the same size as an atom or less. It takes a molecule to hold more than 1 atom. I'll hang my collage diploma on that.Metallic bonding is very different than molecular or ionic bonds. There is another defination of molecule which is more of a lay viewpoint so you could say something like several grains of a steel are a molecule, but in general when you are talking about such issues you don't use lay definations because it will lead to exactly the types of conclusions you are reaching.
I agree that welding to steel is better than electroplating to aluminum.That isn't analagous to damascus, that would be similar to gluing a laminate to a piece of wood. As I noted there isn't a distinct glue in damascus. If you forge weld two pieces of metal together and reharden them they become one piece of metal. The grain structure after forging is recreated and refined by several normalizing cycles and finally set with a austenization and soak.
Note you can see an etching effect very similar to what you see in damascus if you etch an edge quenched blade. You will then see a distinct hardening line. However if you oil that blade you have not then risked the edge from cracking off and the oil will not soak down into that line any more than it will soak into the rest of the blade.
Have you actually seen oil cause a damascus blade to de-laminate and returned this to the maker who told you it was because you oiled it?
-Cliff
As far as i know no one has rubbed oil into or on the blade of a damascus knife every day, so i can't prove it.
So why would you assert it would delaminate, did a maker actually tell you that would happen and that you should no oil damascus?
-Cliff
So you did hear from several makers that oil on a damascus blade will actually cause the layers to separate?
-Cliff
sog, where do you get this stuff from. Please point me to some reference articles that support your supposed facts.
I was told that paste wax should be used.
Fact: Steel has molecules. I was told steel has none.
Chrome delaminates from aluminum.
I think any lamination under the right circumstance will delaminate IMO.
It is stated in this thread that nickel and steel will not delaminate. Prove that! What are the facts there?
