- Jul 22, 2009
Here's my current supplies:
-DMT Duosharp Plus 8" Benchstones(XC, C, F, EF)
-DMT Diamond Pastes(6 micron, 3 micron, 1 micron).
-Chromium Semi-Paste 0.5 micron on Balsa Wood.
-Dupont Diamond Spray 0.25 micron on Balsa Wood.
-EdgePro Apex(120, 220, 320, 600, 1000 grit stones)(least used)
-Paper Wheels(Grit Wheel, Slotted Wheel with white rouge, Slotted Wheel intended for use with Veritas Honing Compound, when I get it).(most used)
-Spyderco Sharpmaker(Med, Fine, Ultra Fine).
Each of these sets have one type of shortcoming or another. EdgePro is very slow at lowering the edge angles, the angles are different on each side, the true angles are different than what you set it at because most knives rest on the secondary bevel, and scratches on the blade from the metal filings are common and require taping over the blade itself(quite a hassle). The Duosharp benchstones can't sharpen recurves and my blades seem to get snagged in the holes every now and then. The Paper Wheels are nice and fast, but it seems fairly easy to end up with a sloppy edge even with 80% of the surface covered in wax to slow the cutting speed(though both the grit and wax seems to last forever). I just got my Spyderco Sharpmaker in today, but the cutting speed of the medium rods seem painfully slow even when the angle is already "in the neighborhood" of 15 degrees per side(not sure about the sandpaper trick, it just seems to make more sense to have an extremely coarse rod for it).
I've been considering a set of Naniwa Chosera and Super stones to experience some of that "authentic" japanese knife sharpening. The problems I see with that is that there will be a constant need for flattening(not even sure how to tell when I should), it will be an exercise in futility with the wear resistant super steels I tend to go for, and I can't sharpen any recurves(which takes my favorite ZT 0301 and BM 710-1 out of the equation).
I'm wondering if I shouldn't just get a DMT EEF Benchstone and call it a day. My stropping technique is pitiful and more often than not seems to dull my edge rather than sharpen it(hence, why I love my slotted paper wheels), thus why I would prefer a more forgiving benchstone with a perfectly flat and solid surface. Also, my last knife sharpened on the EF diamond stone seemed to have an edge that would make a "crisp" cut on paper. It's hard to describe really, but it felt sharper than my previous edges, so I'm wondering if diamonds are the way to go.
