The markings are determine the type of steel the blades are prior to laser marking. Standard production models do not have these markings. Hopefully that helps answer the original question.
And so M4 Griptilian blades with different numbers of holes - those are from different batches - maybe even from different years? Is that correct?
I was going to post up the email response...but the Benchmade mod cleared it up. I understand the logic behind it, but how does every other knife company avoid this? And if it needs to be done, can't it be done cleaner than what was done? Looks terrible IMO.
It's in a hidden spot and has no effect on function, does it really matter what it looks like? Do the aesthetics of a disassembled pocket knife matter to you when making a purchase?
Not trying to be a jerk, just trying to give you some insight into why they probably don't spend much time or care when making the holes.
As for how/why other companies avoid it; they may still mark their blades but in the finishing process the marking is removed, or maybe their process for blanking to heat treat is different and it's deemed unnecessary to mark at all.
I'd be willing to bet that multiple HOLES in a blade would now be the weakest point on a blade.
They're not holes, but indentations. And if they weakened the construction, then we'd had seen loads of broken blades seeing how some users abuse their knives.
They are holes, I took the picture. They go completely through the knife...
