- Oct 3, 1998
Totally agree. Whether you will see a difference will depend a lot on your cutting/sharpening habits.
There was a lovely thread a while ago in which some young fella asked "Now that I bought a D2 blade, what does it do that other steels won't?" The answer: "Go longer between sharpenings."
If you sharpen frequently, you will not see a difference in the performance.
I think this is sorta half the story ... if you sharpen every knife to the exact same edge angle, and sharpen frequently, the differences may not always be as obvious. After all, if the "bad" steel takes 3 weeks before being resharpened, and the "good steel" 6 weeks, how much do you notice? I've always felt that people who sharpen every knife to the same edge angle may be better off with a steel that doesn't horrifically fight the sharpening stone. For me, the standard of a "better" steel is one I can sharpen to a lower angle, without damage doing the common tasks that I use that knife for, while retaining the edge for an acceptable amount of time. If I have to keep one knife at 18-10 degrees per side, and another I can take down to 13-14 degrees -- that is performance I can easily notice. So that's my definition of a "better" steel for a particular job -- for that job, I can take the knife to a lower higher-performance geometry without sacrificing edge life. Taken that way, differences in steel types become much more readily apparent, at least to me. I buy a knife to cut things, so cutting performance is the main critereon for what makes a better steel.
