As luck would have it, the pivot on the PM2 is a T10; so she'll need one.they dont come with t10 but i almost never need that size
Yeah I had to find a separate t10 on the big river,I try to buy made in USA whenever I canAs luck would have it, the pivot on the PM2 is a T10; so she'll need one.
solid.I do not know your level of experience but if you have never taken a Paramilitary 2 apart... it can be difficult to disassemble for the first time as there is the need to defeat the swedged lanyard pipe ends. There is absolutely a learning curve for pulling those flared lanyard pipe ends through the G10 without damage.
When attempting to removing the G10 scale from the lanyard pipe for the first time it is best to take it very slowly. Begin with a careful moderate application of a twisting/pulling/rocking force. You are attempting to pull the larger diameter swaged or flared ends of the lanyard pipe through the slightly smaller diameter hole in the G10 scale. You are wanting that swaged pipe end to worry away a slight amount of G10 material which will enlarge the hole. Work slowly and methodically… as you do not want to damage the lanyard pipe ends. These need to remain perfectly round or circular. It's NOT a Jack Armstrong activity… it takes more patience than effort to pull the pipe ends through the G10 and not damage anything.
Once you have successfully pulled the pipe from both scales you then need to carefully remove the flare from both ends of the pipe. I use a drill… I chuck the lanyard pipe taking care NOT to crush the pipe end. I then spin the pipe and file away the flared pipe end. You ONLY want to take the pipe end down to the same diameter as the rest of the pipe going no further. I also true up the pipe end length a bit just for aesthetics. This is one of those times where you want to check the fit of the lanyard pipe with the stainless liner quite often. Once the end of the pipe snaps easily into the liner hole... that's time to stop filing. If you file too much that will cause looseness issues and possibly a rattling lanyard pipe when reassembled.
Tools needed are...
T-10 Torx for the pivot screws
T-8 Torx for the scale hardware T-6 Torx for the pocket clip screws
If it is not something you are comfortable with I will disassemble and install your new scales on your PM2 at no charge. You just need to send me your knife, the replacement scales, and $3.75 for return postage.
Steve
Do you think I should get someone experienced to do this for me? Honest question for an honest answer. ♡
Tools needed are...
Steve
Just make sure it has a 6, 8, 9, & 10. I've never used a 7 but the knives I have are all pretty common brands and I've used the other 4 sizes.Oh! Also I'm going to get one of these:
You might need to apply force from both ends to get things lose. So you will need to have double of same size of torx bit.
Keep strong downward pressure taking it apart or putting it together or you will strip those screws easily.
Don't over tighten things. Gl
This is how I combat free spinning stop pins and back spacers
