- Sep 30, 2004
Nope.sorry, this is kind of off-topic, but do the black class Benchmade knives typically have a stronger locking mechanism when compared to the blue class?
I have 4 spydercos right now, A delica, Endura, Tasman salt, and a rescue. All have the same Boyd dent lock back. Never heard of how strong these are?? They seem rock solid! Love the lock back!
I believe that means an additional 100lbs per inch. The blade is 4".![]()
It really depends on the model. Spyderco's Military knife has a liner lock engineered to hold over 100lbs per inch of blade.
This makes no sense to me. You're saying per inch of blade, so as per your reply further below, 4 inches on the Military, means it holds 400 pounds. By that assumption, you would say a 10 inch blade holds 1000 pounds. This makes no sense because if you consider basic physics, the blade acts as a lever arm. The longer the lever arm, the easier it is to push. Think of a seesaw. If you sit close to the fulcrum on a seesaw, you can't move the person on the opposite end if he sits further away from the fulcrum.
Are you sure it's not 100 pounds "per square inch" ? PSI rating makes more sense. IF it's a PSI rating of 100 pounds, than if you add 100 pounds of pressure in an area on the blade that's 1 inch long (regardless of where on the Military blade that one inch is (front, back, middle, whatever), the lock will fail.
I personally keep moving towards frame-locks for added safety. They aren't foolproof either, but I find a good titanium frame-lock is solid enough for me to feel comfortable stabbing stuff(not that there's a need to often).
I think a decent answer to your question is that, yes, folder locks are safe but, no, they aren't foolproof. Any can do the job and any can fail under extreme circumstances.
Is a frame lock different than a liner lock or a lock back? Sorry for the questions but I'm learning here.
Bill
Yup, they're all different. Here are some examples; frame lock, liner lock, lock back.
Frame locks and liner locks are similar, but I've found frame locks are typically much safer due to the fact that your hand grip is holding the lock in place.
