kuraki
Fimbulvetr Knifeworks
- Jun 17, 2016
I will say this: I can play stairway to heaven passably (jeers and scoffs), but Jimmy Page did it right.
I think there is an element of grinding that is like that.
Hah, true enough.
In theory yes you are correct (that a jig can work very well for a nmg), and it will work to an extent. But if you want a nice arc in between the two plunges then you will have to do it free hand or sacrifice edge geometry. For an example: here is a reblade for my RHK I was messing with and did on a jig. Notice that it's a straight line from plunge to plunge.
The problem is that the edge thickness will vary if you want a nice arc like on this one (note: not my pic, just pulled it off of google). Notice that the heel and near the forward plunge gets thicker/wider
The reason for this is that the angle must change near each plunge to get a little steeper (e.g. if you are grinding the main hollow at say 3 dps, then it will need to increase to 5 dps near each plunge to keep the edge geometry even). If you have a fixed angled jig (which every one out there is that I know of) then to get the arc your grind will naturally get thinner in the middle.
That all being said is just to demonstrate my point that jigs are limiting but don't require as much skill, free hand is total control/power but requires a lot of learning and skill. Jigs are great in certain situations though, very nice indeed!
I can freehand that grind probably faster any any jig. I don't have anything against jigs but I just spent so much time learning freehand that it's just what I do now. In the future when I become more shaky do to my arthritis and cp I will be forced to jig it up...
This sounds about right Kevin. I think there is such a thing as talent. My dad played guitar really well and could sing. Although I tried for many many years and got fairly good at it, I never had the feel for it. It didn't seem natural to me and I just mimicked what I heard. Grinding however feels very natural to me now. And as you can say, I can feel when it is right and when it isn't.
Let me add this for the OP.^^^ You will find a "Sweet Spot!" like swinging a bat on a softball or a spot on a Tennis racket or for me, the sight picture, stance and hold of my Pistol when I just know, where the bullet is going!
When you present the blade to the belt with just the right amount of pressure and speed on a certain grit belt you will know how the steel will abrade!
This won't happen over night and my sweet spot for belt, speed, pressure at a given grit may be totally different than yours,,, But you will find your Sweet Spot! Where you know its right!
