a suggestion has been posted to make your own paper wheels. this is very dangerous and could even be deadly and never should have been suggested. the forces built up in any spinning object increase with diamater. this can be demonstrated by spinning a ball on a string in a circle around you. the ball gets heavier as it gets farther away from you. the same thing applies to anything spinning and if by chance a piece of cardboard comes loose it becomes a projectile. is saving some money worth the loss of an eye or even death? it only takes once for an accident to happen and its not worth the risk.
The corrugated paper wheels are the same diameter, running on the same motor (same speed), and are of a lesser mass. The real threat is the object being worked on getting caught and striking the person working. When this cardboard is shown to be more dangerous than flap, wire, felt, spiral stitched, loose, or any other wheel I have used over the last twenty years, then I 'll be more concerned over them than something else. Whether or not they are balanced becomes apparent within a second, well before compound is applied, and nowhere near when someone would be prepared to press a blade against them.Angular momentum increases with the speed of the spinning object, the mass of that object, and with the distance of the object from the center of rotation. Each contributes linearly to the total angular momentum.
Paper wheels account for a lot of deaths in the US.
Not sure what all the fuss is about.
Lets not mistake the initial year of membership here with actual experience. Richard and some others here have been sharpening knives for almost twenty years or even more. Also, never do anything yourself that you can pay somebody else to do for you. If you need a drill and you don't have one does it make sense to instead get a firearm and shoot a hole through something? Mostly likely not.
If someone wants to make homemade corrugated cardboard wheels as depicted in this thread than knock yourself out. In my opinion it runs along the same line on whether or not you want to wear a seat belt while driving.
BTW, the Darwin Awards are there for a reason other than being stupid as well as funny. The underlying message being to use a little common sense.
With that in mind, Richard's case should have been duly noted and dissenting opinions read with a grain of salt.
