emann said:
Curious as to which steel most of you feel is the best of these three and the strengths and weaknesses of each. Just trying to get an idea of which one's are exceptable when I'm out knife browsing, and all of these seem to be pretty popular from what I've seen. Thanks for the info.
AUS-6 - AUS-8 - AUS-10 (aka 6A 8A 10A)
Japanese stainless steels, roughly comparable to 440A (AUS-6, .65%
carbon) and 440B (AUS-8, .75% carbon) and 440C (AUS-10, 1.1% carbon).
AUS-6 is used by Al Mar. Cold Steel's use of AUS-8 has made it pretty
popular, as heat treated by CS it won't hold an edge like ATS-34, but
is a bit softer and may be a bit tougher. AUS-10 has roughly the same
carbon content as 440C but with slightly less chromium, so it should
be a bit less rust resistant but perhaps a bit tougher than 440C. All
3 steels have some vanadium added (which the 440 series lacks), which
will improve wear resistance.
440 A - 440 B - 440C
The carbon content (and hardenability) of this stainless steel goes up
in order from A (.75%) to B (.9%) to C (1.2%). 440C is an excellent,
high-end stainless steel, usually hardened to around 56-58 Rc. All
three resist rust well, with 440A being the most rust resistant, and
440C the least. The SOG Seal 2000 is 440A, and Randall uses 440B for
their stainless knives. 440C is fairly ubiquitous, and is generally
considered the penultimate general-use stainless (with ATS-34 being
the ultimate). If your knife is marked with just "440", it is
probably the less expensive 440A; if a manufacturer had used the more
expensive 440C, he'd want to advertise that. The general feeling is
that 440A (and similar steels, see below) is just good enough for
everyday use, especially with a good heat treat (we've heard good
reports on SOG's 440A heat treat). 440-B is a very solid performer
and 440-C is excellent.
