- Nov 21, 2005
I'm looking for a supplier of AUS-8A sheet. Any suggestions?
Thanks!
Mike
Thanks!
Mike
Just educate the customer that AUS-8 is a selling name used by the larger knife companies, and 440-C is the equivalent steel for a hand made knife.
No it isn't. You should not lie to your customers
There is your answer.In what sense is it equivalent besides being mediocre stainless blade steel?
I think you should talk your customer out of it and recommend a better steel. I seriously do not like aus 8 anything...
I feel that an informed customer makes informed decisions. This allows the two of you to decide what is right for the order....
After a little discussion about the steels I use most often, and why I prefer them, I usually upgrade the job to CPM-154 or CPM-S35VN.
The quality of the knife is far greater.
Maybe my words don't translate into your native language the same as I meant them ( you haven't filled out your profile, so I don't know if you are in another country.). I never advocated , nor ever tolerate, lying to the customer.
Equivalent means just what it says..."Equal in value"......not identical, but similar enough in quality to be used in place of something.
What I was saying is that educating your customer about the steels available is how to deal with a request you can not do. AUS-8 is a commercial steel used by larger manufacturers, but not readily available to the small maker. The big manufacturers use it because it is cheap and makes an OK, but not outstanding knife.
As far as the line about the carbide sizes and V content, stating that it makes AUS-8 a greatly superior steel is lying to the customer.
If one wishes to get on the subject of misrepresenting steel types, many commercial sellers of blade blanks and finished blades sell the identical blade as AUS-8 one day, and then 440-C on another day.
If you want a lower grade steel, I have to order it, customer gets to pay for the time, hassle, and probably the rest of the bar of steel.
