- May 18, 1999
I don't think it's anything I'm doing during disassembly, but I have been known to be wrong in the pastI'm a tinkerer, and if the action of my knife still feels sticky after oiling and a break-in, I usually break it down and polish the washers. That's it. Once the knife is running smoothly, I don't have a need to take it apart again. But with my 940-1, usually a few months of use later I'll open the knife and break a spring. This is the only "Axis Lock" knife I can speak of however, because it's the only one I've owned.
Fidgeting with the Axis lock probably means more than 10 times in rapid succession, am I correct? The more you do it in rapid succession, the faster the spring will heat up and it's temper will be affected, causing premature failure. I can go 10 years without a spring failure -- even opening it hundreds of times -- because it is not done all at once, thus no heat buildup, thus no loss of temper.
