- Jan 5, 2015
Gotcha... The maker should fix the spring.
Yep I agree with Don,no way did that cause the spring to break. Maker should replace the spring IMHO.
Thank you guys! And others that have chimed I
Almost always too high RC . Only other is too much preload on the spring. Scallops didn' help . I have made just under 2K slipjoints and broke two springs due to too much preload on one and wrong RC on the other.
I'm not sure how filing a sharpening notch into a part of the blade that doesn't even contact the spring, could have anything to do with it's failure.
Seems like bad geometry or a bad heat treat, as others have said. Did the knife have a stiff pull?
At any rate, it's a crying shame when a maker isn't man enough to stand behind his work, but would rather make lame excuses. Looks like a really nice piece otherwise.
Good deal!
