Spyderco ether Endura or Delica would be a good choice. I just love my Delica, and ever since I got it its been my EDC (every day carry).
Before I got it I was unsure about the HOLE design, but I think its brilliant. The knife always opens smoothly with or without gloves.
I got the Delica with a combo edge. I usually prefer a combo knife, but with the Delica the plain edge part is a bit small. So if I was to buy it again I would probably go for the plain edged.
I highly agree! I got my Delica 5 days ago (Monday), and I've been in love ever since. I was unsure about the hole as well, but now I'd rather have a hole than a thumbstud on any knife (well most). I got the plain edge right off the bat, though
It seems like the vote is for Delica over Endura! Which was my initial thoughts, because the Endura did seem a bit slim looking. (actually! Check later down on this post!)
You won't regret either one, I assure you.
Also, what did you mean by 'flat grind over sabre ground' Vivi? From the pictures I saw from looking up the knives you suggested it seems like the blade is only 'sharp' at the edge, rather than for a greater width. Is that right?
It's kind of hard for me to explain what the grind is... With a Flat Grind, it's like the blade is a triangle wedge shape. From the top of the blade to the edge, it is completely flat.
A Sabre Grind has a section from the top of the blade going down that is all the same width (the lines would seem to go "parallel"), and then it starts to angle into the edge. A Hollow Grind would be about the same, except instead of being flat where the angle goes into the edge, that angle would be slightly curved.
Basically, the grind affects the cutting ability of the knife.
It's all kind of hard to explain in words. If you download Spyderco's catalog, it's all explained in the back, and examples are given.
http://www.spyderco.com/catalog/download.php
The DELICA's blade length seems a bit SHORT. Maybe because I'm not holding it, but I actually like the length of the Endura. Maybe it's because I'm *new* and I haven't handled them for an extensive amount of time.
Looking at the specs online, I thought the same thing. I thought I was going to go for an Endura. Then I saw them in real life and decided that the Delica actually had a better size than the Endura (I was looking for a not-huge knife).
This is my Delica; the picture seems to be actual size:
This leads me to ANOTHER question! Is the difference between a Spyderco COMBINATION EDGE and SPYDEREDGE that the Combination has LESS of a Spyderedge while the Spyderedge nearly takes up the whole blade?
Plain Edge: No serrations
Combo Edge: Serrated on the rear half of the edge
"Spyder Edge:" Fully serrated from the front of the edge to the back.
